#57149 |
Where in the heck IS everybody?
This is as slow as I've seen this forum in many ah moon - ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Leonardo (06-13-2019) |
#57150 |
Country Boy 4 Life
![]() Quick update on the "new" project. (my 26 year old Chevy G20) Last night I used a grinder on any areas that were showing rust on the inside. There were rust bubbles on an area under my side window, so I took the window out to see how bad the edge was rusted. I then began sanding down the edge and getting ready to prime and paint all the prepped areas. The side window had ZERO calking of any kind. And the old rubber gasket failed a long time ago. So the edge was not as nice looking as I had hoped. Still, I learned a bunch, and my confidence in my capability is growing. (I am having fun!) There was a ton of black tar like stuff on areas of the floor. I removed it. Now have to use some solvent to get the rest. You can see its still on the paint, even though I got most of it. ![]() I have SikaFlex -715 I plan on using for the widow (and my Maxxair Maxxfan Deluxe - I'm only a bit worried about cutting a hole in my roof for it ) and possibly some Dicor sealant tape. After getting the rust primed and the holes in the floor patched with fiberglass sheet and resin, I'll begin the wiring process, then start insulating. That's all for now.
I LIKE TIRES! |
| The Following 5 Users Say Thank You to Leonardo For This Useful Post: | EAGLE5 (06-13-2019), humfrz (06-13-2019), NoHaveMSG (06-13-2019), ScoobsMcGee (06-13-2019), spike021 (06-13-2019) |
#57151 | |
Dismember
Drives: 2013 Red Scion FR-S
| The Following 4 Users Say Thank You to EAGLE5 For This Useful Post: |
#57152 | |
Country Boy 4 Life
We will also be traveling with our obligatory cute puppy named Lulu. (shes been helping with the build. "Hand me that 7/16 socket Lulu" )
I LIKE TIRES! |
| The Following 7 Users Say Thank You to Leonardo For This Useful Post: | EAGLE5 (06-13-2019), NoHaveMSG (06-13-2019), ScoobsMcGee (06-13-2019), soundman98 (06-13-2019), spike021 (06-13-2019), Spuds (06-13-2019), wolffbite (06-13-2019) |
#57153 | |
Just the tip
Drives: 2017 DGM BRZ
Many of these cars also have that pesky start-stop feature. I disable that right away if I can. Always renews my appreciation for the overall driving experience of the brz. |
#57154 | |
Drives: Subaru BRZ
Managed to secure the STI engine and transmission mounts!! Want to get back to 'Un-Known' to chat through clutch, TOB and flywheel with the garage... little things make me happy.. work makes me sad..(correction, I enjoy my work but my company's MO irritates me immensely!). |
| The Following User Says Thank You to JD001 For This Useful Post: | humfrz (06-13-2019) |
#57156 | |
The Dictater
Drives: '13 Red Scion FRS
#57157 |
Wayward Member
Drives: Hot Lava 86
I'm not sure if I'm missing something/doing a terrible job, or if they didn't think my new role all the way through because I keep running out of work. No clue what to do for the next two hours.
#57158 |
Famous Potatoes
Drives: '15 ultramarine
That was my job for the final 6-7 years. I could do my job in about an hour a day. I read lots of books, and did lots of shit posting, etc..
| The Following User Says Thank You to Sapphireho For This Useful Post: | Nevermore (06-13-2019) |
#57159 |
Wayward Member
Drives: Hot Lava 86
I'd leave early but I'm still on a temp/visitor badge and I have to sign in and out. I'm just afraid someone is checking those logs.
#57160 |
Drives: jrsc_brz
DRAG QUESTION
dont know where to ask this and dont want to start a new thread i want to take it to a strip, rules say i need a overflow can for radiator. is this not the same as the coolant reservoir? point me in the right direction? i googled and saw a perrin one for ~150$ just thought id ask. trying to do my homework. |
#57161 |
#57162 |
Famous Potatoes
I'm too tired to pack today. 17 more days in California.
| The Following User Says Thank You to Sapphireho For This Useful Post: | EAGLE5 (06-13-2019) |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 08:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 11:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 11:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 06:18 AM |
