FRS trunk not opening
I have another post floating around here somewhere. I was away for awhile and now back dealing with the same issue. My trunk won’t open. I pulled the back seat down. The valet mode button is off. You can hear the trunk pop when you push the trunk button on the key fob but nothing happens. The emergency pull doesn’t work. It won’t open with the key. Any suggestions before I go back to the dealer. It’s a 2013. Thanks.
#2 | |
Sent from my SM-G975U using Tapatalk |
#3 |
Yeah - the emergency pull not working is weird. That's a direct, mechanical connection to the release mechanism. It's odd that you can hear it unlatch but it still doesn't.
#4 |
Drives: 17 86
Stupid questions. Once you hear it unlock, have you tried pulling/pushing the lid open? Have you tried lubing the latch? It may not be opening enough to release.
| The Following User Says Thank You to PetrolioBenzina For This Useful Post: | lorip713 (06-10-2019) |
#5 | |
Are you sure the latching mechanism is being released? Insure that opener lever inside the car has returned to its down position? Are you pushing the valet switch the "open" way? Insure that you are pulling the emergency rip cord the proper way? OK, now that you are sure the latch is releasing, I suggest the following: * have someone push and hold the trunk button the FOB, while you are aggressively pushing down and pulling up on the trunk lid. * if that don't work have someone hold the button down, while you crawl into the trunk space and pound "up" in the trunk lid from the inside. Iffen none of that works, either break out a crowbar or take it into a shop. Let us know when you get it open - humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | lorip713 (06-10-2019) |
#6 |
ProCrastinationConsultant
i would suggest putting some pressure on the trunk lid while hitting the trunk button on the remote. sometimes it can be latched too tightly.
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
#7 | |
I’m not even sure how to do that. I don’t see anything to lube instead the trunk. Just a black box covering where the latch might be. |
#8 |
#9 |
Drives: 2016 Halo FRS
Are you able to get into the trunk from the cabin and using a screwdriver to move the lock over to one side to release the mechanism?
#10 |
#11 |
| The Following 5 Users Say Thank You to p1l0t For This Useful Post: | humfrz (06-11-2019), Leonardo (06-11-2019), soundman98 (06-11-2019), Ultramaroon (06-11-2019), venturaII (06-11-2019) |
#12 | |
humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | p1l0t (06-11-2019) |
#13 |
wow. JUST SAY NO to tool-on-tool violence!
| The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (06-11-2019) |
| Trunk opening after "spirited" uturn. | JDM FRS | Issues | Warranty | Recalls / TSB | 30 | 08-22-2013 10:08 PM |
| Trunk not opening | grgonium | Issues | Warranty | Recalls / TSB | 4 | 02-06-2013 03:47 PM |
| trunk opening it self | Im_SPEED | Issues | Warranty | Recalls / TSB | 12 | 09-10-2012 10:49 PM |
| Trunk not opening | FRomar-S | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 08-16-2012 05:23 PM |
| Opening in GTA group buy | Sport-Tech | CANADA | 6 | 05-23-2012 11:17 PM |
