Old 06-11-2019, 03:56 PM   #57
wparsons
wparsons's Avatar
Originally Posted by venturaII View Post
Or if all you're looking to do is reduce lean a bit, and you're otherwise fine with the existing spring rates and balance, buy a set of bars that increase the diameter uniformly and call it a day.
I wouldn't do that, I'd look for a set that increase the front and rear roll stiffness by the same amount.
1mm more on an 18mm bar is going to be different than 1mm more on 14mm bar.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Spuds (06-13-2019), Ultramaroon (06-11-2019)
Old 06-11-2019, 03:59 PM   #58
wparsons
wparsons's Avatar
I don't think he's disputing the obvious fact that sway bars tie both sides together to a certain degree, as they do with the factory setup. It's that going to a moderately larger bar doesn't immediately turn the suspension into a beam axle. Yes, some movement gets transmitted to the opposite side, but then again, that's how they're supposed to work in the first place.
I don't think he got that at all, and that's what I was pointing out. End links or attached directly to the strut, the only independent movement is through the sway bar twisting. We definitely agree on that, I was clarifying for the other guy.
flickr
Old 06-11-2019, 04:08 PM   #59
Even if the effective spring rate ratio between front and rear sway is maintained, the real-world results are still unpredictable. That's one of the things I learned studying this stuff formally. Do all the math to get ballpark but, even with today's numerical methods, that's all it'll be, ballpark.
Of course, for most of us, myself included, ballpark is all that matters.
Spuds (06-13-2019), strat61caster (06-11-2019)
Old 06-11-2019, 05:46 PM   #60
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I wouldn't remove the swaybars from a suspension that was designed to work with them. The only application I can think of it would be off-roading usage, but this is not very relevant to our platform.
The Following User Says Thank You to nikitopo For This Useful Post:
norcalpb (06-11-2019)
Old 06-12-2019, 08:22 AM   #61
Tokay444
A lot of fast FWD racers remove the rear sway, setup an extremely stiff front bar, and just drag a limp ass around.
Old 06-12-2019, 09:59 AM   #62
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
That's just basic math, but considering no one sells sway bars in tenth of a millimeter increments, the point I was trying to make was to buy a set that are as closely matched to the f/r ratio as the stock ones are, assuming no change in balance is wanted. No set will maintain the exact same rate ratio, simply due to how diameter increase changes torsional resistance exponentially, and that available sizes are not granular enough. But, they're close enough, generally, so that an even increase doesn't alter the balance much. Eventually the math would work in favor of an uneven increase, but I think that'd be a pretty sizable change at that point.
Also keep in mind that even though the rate rises exponentially, it's still a relatively small fraction of the total roll resistance at that wheel. As mentioned before, it's generally a tuning device if your existing setup is close to what you like.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 06-12-2019, 10:06 AM   #63
venturaII
venturaII's Avatar
Again, platform dependent. There was a popular suspension outfit at one point who had a very fast kit for A1 chassis VWs which did away with the front swaybar completely, and used a gigantic Carrera bar in the rear... The cars were undeniably quick, so the setup worked; it was just quite unconventional compared to the majority of other kits at the time.
The Following User Says Thank You to venturaII For This Useful Post:
Tokay444 (06-12-2019)
Old 06-12-2019, 10:13 AM   #64
Racecomp Engineering
The difference in effective wheel rate you get from going 1 mm stiffer in front vs 1 mm in the rear is a good point many often miss.
But what I think @Ultramaroon was getting at was...even if you increase front and rear wheel rates by exactly the same 10%, you could still be changing the handling balance of the car.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
Spuds (06-13-2019), Tristor (06-12-2019), Ultramaroon (06-12-2019), wparsons (06-12-2019)
Old 06-12-2019, 10:25 AM   #65
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have always seen the opposite on FWD cars to try to get the car to pivot more around the front.
ZDan (06-12-2019)
Old 06-12-2019, 10:50 AM   #66
Tokay444
I have seen this, but not always. Nothing is ever absolutes. The theory is, you don't want wheels you aren't putting any power to, doing the any oversteering.
Old 06-12-2019, 11:10 AM   #67
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is the opposite of what I have heard on FWD. They are trying to eliminate push so you have to take grip from the rear to get the car to pivot. If you watch some exterior video a lot of the times they will lift the inner rear tire from the front being so soft and the rear being so much stiffer (in respect to roll balance) . This is really obvious on even stock performance trim cars like the Fiesta ST.
Spuds (06-13-2019)
Old 06-12-2019, 12:06 PM   #68
RayRay88
Drives: 2017 86 860 Special Edition
Agree, having owned an EK in the past. Honda Tech's race forum is riddled with large rear hollow bars and over sprung rear rates.
Not uncommon to see 12K front and 18K rear.
Recently the front biased stagger is becoming the norm. A lot of Japanese tuners use this to get the car to rotate better to great effect.
RayRay88 is offline   Reply With Quote
The Following User Says Thank You to RayRay88 For This Useful Post:
NoHaveMSG (06-12-2019)
Old 06-12-2019, 12:24 PM   #69
Tokay444
Like I said, nothing is absolute. I've seen devastatingly fast FWD cars with no rear bars at all.
Old 06-12-2019, 12:39 PM   #70
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah I have no doubt. Sway bar is not the whole story. I know there is a CRX over here that does hill climbs and pretty much runs no rear suspension. I know a bunch of drift guys out here run stupid stiff setups with no bars at all, but drifting so I am pretty sure that with my 6k/6k rates that my sways are not a huge part of my setup, just that them being adjustable allows me to change the behavior of the car a bit.
FS: Cusco Strut Bars and Power Braces, Hotchkis Sway bars armyoffoo Brakes, Suspension, Chassis 10 08-08-2018 08:28 AM
Oem sway bars Marks Boosted Brakes, Suspension, Chassis 2 07-20-2017 07:29 PM
WTB F&R sway bars blkmamba Canada Classifieds 1 06-04-2017 02:15 PM
FR-S stock sway bars compared to TRD bars babydriver Scion FR-S / Toyota 86 GT86 General Forum 3 12-01-2014 09:12 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
