Old 06-11-2019, 10:30 AM   #71
fika84
fika84's Avatar
Originally Posted by secho View Post
Hello there,
just found this thread most appropriate. Maybe somebody can help guys.
After rebuilding FA20 engine I have got issue with the intake cam avcs angles. It fires P000A and P000C (slow response to avcs command).
Engine setup is:
Cosworth supercharger
OEM crankshaft
pCoteMax Kings main and rod bearings
Bridgeway forged rods
JP pistons CR12.5 86mm
machined heads and block
DW 450cc PI
baffled sump plate
CUSCO water oil cooler
mishimoto thermostat (the one which comes with the supercharger kit)
I think about several reasons:
- bad one or both OCV selenoids ( less probable, because before disassembly of the engine, cams worked ok, I checked the previous logs)*
- incorrectly aligned timing chain (less probable, because engine goes more-less ok)
Can I ask you for your opinion please? Check the logs bellow.
intake cams
• there is rapid oscilation of both cams all the time
• none of the cam goes over 20FR deg
• cam 1 is performing better than cam 2
https://datazap.me/u/secho/loguju-va...mark=9166-9354
intake cams angle ugly oscillation
https://datazap.me/u/secho/loguju-va...zoom=5408-5893
exhaust cams*
• actual angles fluctuates much more when the oil temperature is low (one cam more then the other)
• fluctuation stabilises when the oil temperature rise (both cams ok)
• it follows target exhaust angles*
https://datazap.me/u/secho/loguju-va...mark=1384-8114
Please let me/us know what you find with this. My intake cams are doing the same thing after engine rebuild and I'm about to take the engine back out to clean the cam gears more thoroughly!
fika84 is offline   Reply With Quote
Old 06-11-2019, 12:56 PM   #72
secho
secho's Avatar
Drives: GT86, forged and supercharged
Finally I ended up changing all 4 cam gears for new parts. The most expensive way. But now it works flawless.
secho is offline   Reply With Quote
Old 06-11-2019, 02:43 PM   #73
fika84
fika84's Avatar
Sounds like the path I'm headed down.. I've concluded that it's not electrical by moving around sensors, solenoids and changing tunes. It has to be oil passage related.
Thanks for that info!
Old 06-11-2019, 02:58 PM   #74
secho
secho's Avatar
While rebuilding engine, did you removed cam timing oil control valve filter in the heads sub-assy? They could get clogged. See the pic.
Odesláno z mého SM-G973F pomocí Tapatalk
Old 06-11-2019, 03:32 PM   #75
fika84
fika84's Avatar
Oh yeah, I ripped those bitches out!
Cam timing adjustments without dyno StormTrooper Software Tuning 17 02-19-2014 04:16 PM
POST UP YOUR DYNO FIGS!![Nat. Asp]DYNO Figures (BEFORE and AFTER) stevo_12v Engine, Exhaust, Transmission 10 12-19-2013 02:02 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
