Old 06-09-2019, 08:11 PM   #1
Zaraia
Drives: 2015 Scion Frs
Won’t go into gear easily.
So a little background, I’ve had my clutch replaced, apparently it was slipping, I wouldn’t know, I was stationed in Japan while my father was taking care of my frs, so I bought a stage 2 clutch and one flywheel and told him to go get it replaced, now that I’m home as soon as I get in the car I realize first and second gear are really hard to shift into, could anyone help me out, I plan on fixing this myself now that I’m here. Any help would be appreciated please and thank you.
Zaraia is offline   Reply With Quote
Old 06-09-2019, 08:52 PM   #2
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
If you're using a stronger clutch with the stock shift fork it could cause it to fatigue and bend which would make it more difficult to get into gear.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Zaraia (06-10-2019)
Old 06-09-2019, 09:39 PM   #3
I would have suggested you take it back to whoever installed the clutch and ask them to fix it.
However, since you want to DIY, I suggest you adjust the clutch.
Zaraia (06-10-2019)
Old 06-09-2019, 10:49 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm assuming you mean while the car is running. how about when the engine is off, once the syncro's line up, does it pop into gear easily then? i'm wondering if your dad might have used the syncro's more then he should have. probably thinking too hard though.
Zaraia (06-10-2019)
Old 06-09-2019, 11:07 PM   #5
If it goes into third, fourth, and reverse ok, it's another case of sloppy top plate alignment.
https://demos.starbase7.net/t3Portal...05HBC002X.html
DarkPira7e (06-10-2019), Sportsguy83 (06-10-2019), Zaraia (06-10-2019)
Old 06-10-2019, 03:42 AM   #6
Zaraia
I think you might be right, it goes into every other gear just perfect.
Old 06-10-2019, 12:36 PM   #7
I bet if you lift the lockout ring, you'll find the first and second gear gates easily. :/
Old 06-10-2019, 03:43 PM   #8
Zaraia
I just wanna thank you guys for all your input, none of you had to stop and reply but you guys took time out All of your days to help me. Im really greatful.
The Following 2 Users Say Thank You to Zaraia For This Useful Post:
Sportsguy83 (06-10-2019), trvth (06-12-2019)
Old 06-10-2019, 03:55 PM   #9
Absolutely! Sucks to be in the dark. See the link to all the [unofficial] service manuals in my sig line. Not my content but thrilled that it's available.
I've been told that some of it is not up to date but...
soundman98 (06-10-2019), Sportsguy83 (06-10-2019)
Old 06-10-2019, 10:26 PM   #10
soundman98
soundman98's Avatar
that's what forums are all about!
Old 06-10-2019, 11:11 PM   #11
I should compare my method to the book.
  1. Loosen the top plate until it can be moved around with a little bit of resistance.
  2. Shift into first and find the middle of the gate.
  3. Holding the gearshift in position with one hand, butt the top plate against the foot of the lockout.
  4. Do the same in second gear.
  5. Tighten the screws just a touch.
  6. Check work and repeat if necessary
  7. Torque to spec.
There's no way you'll find that in a modern manual because it's not idiot proof.
Engine Bay easily gets dirty? leevanf Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 06-17-2018 02:53 PM
Paint stains easily? DarkSideFRS Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 09-28-2017 05:59 AM
Easily Reversible Mods Westen BRZ First-Gen (2012+) — General Topics 13 03-18-2016 11:41 AM
Stock Tires - Slips Easily djmm Scion FR-S / Toyota 86 GT86 General Forum 97 01-15-2015 01:38 AM
Is the Front Grill of the FR-S easily removable? Hentai DIY (Do-It-Yourself) Guides 4 01-12-2015 12:52 AM
