CANADA Canada
Old 07-18-2012, 09:09 AM   #57
Dragon86
Drives: Whiteout FR-S MT
ok, i'm also part of the chirping club, and my car only has 500km on it lol. Anyone find out what it could be?
Dragon86 is offline   Reply With Quote
Old 07-18-2012, 09:14 AM   #58
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so which gas are you using?
Old 07-18-2012, 09:26 AM   #59
Dragon86
continued with dealer 91 octane.
Old 07-18-2012, 09:27 AM   #60
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
ESSO, Shell, Petro, Canadian Tire, Husky..... wallmart?
Old 07-18-2012, 10:25 AM   #61
Dragon86
Petro 91 Octane
Old 07-18-2012, 10:37 AM   #62
Future
Future's Avatar
Drives: BRZ!
Change to Shell... = problem solved for me.
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 07-18-2012, 10:38 AM   #63
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Petro 91 Octane
Not all gas is created equal. Petrocan uses up "to 10% ethanol"
Try Shell or ESSO 91 instead.
I prefer Shell.
Old 07-18-2012, 11:00 AM   #64
drei
drei's Avatar
Drives: 2013 Scion FR-S Asphalt
I've been using only Shell 91
drei is offline   Reply With Quote
Old 07-18-2012, 11:55 AM   #65
Dragon86
I prefer Shell.
The chirping from the engine is caused by the gas used?
Old 07-18-2012, 12:01 PM   #66
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it seems so, yes
the injectors don't seem to like fuel containing ethanol, and Petro can has the highest ethanol mix out of the other major brands.
It actually states in the manual not to use fuels with ethanol mix.
Shell 91 is claimed to have none.
Old 07-18-2012, 12:26 PM   #67
Dragon86
it seems so, yes
Oh well gives me an excuse to burn fuel, however i'm still in break in period lol.
Old 07-18-2012, 01:01 PM   #68
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Not sure what the dealer put in, but I've put two tanks of Shell V-Power 91 (no ethanol) so far and things seem fine enough!
Rossman is offline   Reply With Quote
Old 07-18-2012, 01:38 PM   #69
Heero
Heero's Avatar
Drives: 2-door
it seems so, yes
Huh? Where did you read this?
Almost all gas in NA contains up to 10% ethanol. I can't imagine ethanol causing any damage to the car. And TBH the 10% is a catchall number, I would guess it is much lower then that.
No where in the owners manual does it say not to use fuels with ethanol mix. Most gas in Cali has 10% ethanol no?
And 93 or higher is recommended according to the manual - but it does state that 91 will run without detriment to engine durability or driveability.
Again: Fuel used should not have any effect on the vehical so long as you are using 91+.
At the end of the day however, there are two gases you should use.
1) Petro 94
2) Shell VPower 91 (not the regular 91, the 1 with zero ethanol).
Personally I use Petro 94 because it is widely available to me whereas Shell is a little out of the way.
Heero is offline   Reply With Quote
Old 07-18-2012, 01:44 PM   #70
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
where did i get this?
i got this from the 370+ thread on engine chirping in the engine/tuning sub-forum
http://www.ft86club.com/forums/showthread.php?t=9836
where have YOU been
as for ethanol causing or not causing damage, i'm not going to get into it because i'm not a chemist, but the owners manual specifically says not to use it, so you can do whatever, but i'm switching back to shell (been a custom all my driving life).
The Following User Says Thank You to 7thgear For This Useful Post:
drei (07-18-2012)
93 Octane Smokinbuffalo Northwest 20 09-02-2012 05:24 PM
93 Octane? ashtray BRZ First-Gen (2012+) — General Topics 175 04-04-2012 12:22 PM
Subaru called me today adam AUSTRALIA 34 04-04-2012 06:27 AM
UK Launch. FT-86 is called GT 86 mrxandthexfactor Scion FR-S / Toyota 86 GT86 General Forum 1 11-26-2011 11:08 PM
What will it actually be called? Hounddub Scion FR-S / Toyota 86 GT86 General Forum 13 09-28-2011 09:58 AM
