Old 06-06-2019, 05:51 PM   #1
deku
Drives: 2017 subaru brz red, 93 FD RX7
best size for new tires
Hey guys, so i'm currently on the 17x7.5 pp wheels and i will be going to a 18x8 summer set up. im looking at the wheel it fit calculator and wanted to know if there is a benefit or effects between going 225-45r18 vs 235-40r18?
deku is offline   Reply With Quote
Old 06-06-2019, 05:59 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
You want 225/40-18, nearly stock diameter. 225/45-18 is an inch too tall...
235/40-18 is a bit tall as well (+0.7") and IMO 235 wants an 8.5" wheel width anyway.
Old 06-06-2019, 07:11 PM   #3
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Second vote for 225/40
its what im running on the stock tS's 18x8 and its the proper size and height and price. anything more than 225 is too much tire for an NA car anyhow
Clutch Dog is offline   Reply With Quote
Old 06-06-2019, 07:17 PM   #4
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
If you want to keep the diameter of the tire as close to the factory spec as possible, then I would recommend that you get 235/35/18.
235/35/18 would be 0.6% smaller in diameter than the OEM Michelin Primacy's, and a 235/40 would be 3% larger in diameter than the factory tires.
-Sam
eastendraceshop is offline   Reply With Quote
Old 06-06-2019, 07:46 PM   #5
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
A 235/35R18 would be the closest in terms of diameter, however isn't a super common size compared to the 225/40 (limiting tire choice). Being that your next set will be 8" wide; the 235 may be a little on the wide side.
A 225/40R18 is the correct width for an 8" wheel, and the added sidewall height will only help counter the increased harshness by going up in wheel diameter.
We run 245/40R17's on our shop BRZ, which is actually even larger in diameter.
Edit: 245/40R17 and 215/45R17 are within a few millimeters in diameter.
WORKS is offline   Reply With Quote
Old 06-07-2019, 09:41 AM   #6
deku
it looks like im going to go with 225/40r18. thanks guys
Old 06-07-2019, 10:47 AM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Lmao! 235/35/18! That is a super rare size that is stupid expensive!
225/40/18 is the CORRECT size.
I LIKE TIRES!
Old 06-07-2019, 10:56 AM   #8
TommyW
TommyW's Avatar
Drives: '13 Whiteout
225. There are just sooo many more choices and 225's are plenty for this car with stock power.
TommyW is offline   Reply With Quote
Old 06-07-2019, 10:59 AM   #9
Jordanwolf
Rice King
Jordanwolf's Avatar
Am I being lied to? 245/40/17 is very close to factory 215/45/17.. No?
Source: https://tiresize.com/calculator/
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 06-07-2019, 11:05 AM   #10
WORKS
WORKS's Avatar
Oops! Yes, you’re correct. They’re very close. I was thinking of another tire combo for some reason. Factory AP2 s2000’s actually run a 215/45 front, 245/40 rear. They’re within 3 millimeters in diameter.
That being said, my statement stays the same regarding recommendation. 225/40R18 would be the way to go for an 18x8 on a BRZ.
WTB: 215/45/17 tires (stock size) tjed147 Want-To-Buy Requests 7 10-04-2017 11:52 AM
tires size - 225/50/18 AE86_Mikko Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-27-2013 09:44 AM
Anyone running 225/45/17 tires? How do you like that size so far? Chimpo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-01-2012 02:24 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
What size tires should I get for 19s? mrha Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 12:23 AM
