Old 06-05-2019, 04:16 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by SmartedPanda View Post
Can I ask how you personally did it? I might just pull the trigger cuz there's a sale at Jeg's right now.
I will try to get a picture for you. I am mistaken, I have the PC925 but going to be the same idea.
SmartedPanda (06-05-2019)
Old 06-06-2019, 01:13 AM   #16
86TOYO2k17
Drives: 2017 toyota 86
About 20minutes, and 20$
Make your own bracket.
Probably way overkill but it’s 10times more secure then OEM, can remove battery/bracket with one hand it’s so small and light.
Old 06-06-2019, 02:11 AM   #17
Tristor
Tristor's Avatar
I have never attached a tender on my car, max is about 1 week without driving though. I have a Shorai LFX36L3-BS12 which weighs 4.8 pounds, plus the PTuning billet battery tray which weighs 30oz. Total weight is 6.8 pounds vs 31.5 pounds for factory battery and tray. That's a weight savings of over 24 pounds and I never once had to put a tender on it or worry about it failing to crank here in Texas.
An Odyssey PC680 weighs 15.4 pounds and then you need a tray still. Just get the Shorai. Don't jump it though, you can't jump any Lithium batteries, they'll catch fire.
Tristor is offline   Reply With Quote
Old 06-07-2019, 01:44 AM   #18
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Forgot i got a blackvue dashcam too.
I narrowed it down to the Optima or a Braille.
Found my mounting solution: https://www.jegs.com/i/Braille-Batte.../6188/10002/-1
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 06-07-2019, 01:01 PM   #19
Tristor
Tristor's Avatar
What made you choose that route?
Old 06-07-2019, 01:49 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I would stick with Odyssey over Optima. Much better quality, I see a lot of dead cells with Optima over a short period of time.
Old 06-07-2019, 02:14 PM   #21
SmartedPanda
I'm sorry was half asleep,
Odyssey or Braille.
Braille seems like a better choice since I run a dashcam + parking mode.
Unfortunately I've seen better reviews for Odyssey, and inconsistencies with Braille/Deka batteries.
Old 06-08-2019, 05:25 PM   #22
Jdmjunkie
Drives: Scion FR-S 10 Series
Depending on how much money you are looking to spend, this is what I would get. It is in the stock case size, so no modification necessary. And it is extremely lightweight. It also should not need a tender.
https://shop.antigravitybatteries.co...tive/ag-35-rs/
Jdmjunkie is offline   Reply With Quote
Old 06-08-2019, 06:43 PM   #23
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
If you run a Shorai you MUST have a tender and be diligent in keeping it at over 13.1 volts. Had the biggest, most powerful Shorai and it became a paperweight in about 6 months of daily driving. Not recommended at all for daily driving unless you ALWAYS keep it on a battery tender. I've run Odyssey batteries on every one of my vehicles and never had any issues with them (other than stupid Nissan dealer killing the nearly brand new one in my Frontier from extreme negligence). Have run the PC680 with metal jacket in my FR-S for years... don't tend it and have zero issues. The PC680 would be the smallest battery I would ever use in a car for daily duty without a tender...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 06-08-2019, 07:27 PM   #24
Tristor
Tristor's Avatar
Wow that's absurdly expensive considering it weighs more than double what a Shorai weighs.
"Best" Battery Tender for long term BRZ storage? joro2 BRZ First-Gen (2012+) — General Topics 10 10-02-2017 01:37 PM
Battery tender charging through cigarette outlet? imom BRZ First-Gen (2012+) — General Topics 13 01-11-2017 12:18 AM
Anybody using Battery Tender JR? bhbnuckle CANADA 14 11-26-2014 04:00 PM
Shorai Battery, Tender, and PTuning Tray jack43 Engine, Exhaust, Bolt-Ons 4 08-23-2014 12:42 PM
Suggestion: Marketplace / Tender forum ft_sjo Site Announcements / Questions / Issues 2 08-31-2013 04:03 PM
