Old 06-05-2019, 10:27 AM   #71
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Do you have a picture of the final result? Just want to check how much they work ...
Old 06-05-2019, 10:46 AM   #72
tomm.brz
Drives: brz 2017 hksv2
i do have them, driver side still sags like they aren't there as before just after 1 month
but well, not much
nikitopo (06-05-2019)
Old 06-05-2019, 12:50 PM   #73
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
BigTuna is offline   Reply With Quote
The Following 2 Users Say Thank You to BigTuna For This Useful Post:
Bonburner (10-03-2020), nikitopo (06-05-2019)
Old 02-27-2020, 05:29 PM   #74
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I was looking for a while for this post, and I just wanted to throw a new post in here for this thread to get more visibility.
DandoX is offline   Reply With Quote
Old 05-01-2020, 10:31 PM   #75
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Bump. Does anyone know if Toyota has a TSB for this?
Bach415 is offline   Reply With Quote
Old 05-02-2020, 02:33 AM   #76
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I still have this bumper plate. Waiting to install it when I'll remove the bumper at some point of time. Not so urgent currently ..
Old 05-02-2020, 05:15 PM   #77
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
How many did you ordered? 2 or 4?
Old 05-02-2020, 05:33 PM   #78
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I ordered 2. One for each side.
The Following User Says Thank You to nikitopo For This Useful Post:
ichitaka05 (05-02-2020)
Old 05-02-2020, 05:43 PM   #79
ichitaka05
Site Moderator
ichitaka05's Avatar
That's what I was thinking as well. I'm replacing my front bumper, so mind as well get that plus new support rails to get it tightly fit again.
Old 05-02-2020, 05:51 PM   #80
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Does your car not have this issue? It is my understanding that EVERY Twin will eventually deal with this.
What is this issue exactly?? I’m not sure if my car has the problem?
JesseG is offline   Reply With Quote
Old 08-11-2020, 01:26 AM   #81
jtiptonk
jtiptonk's Avatar
Drives: 2013 WRB Subaru BRZ Limited 2.0
Essentially your bumper pops out of its clips and is no longer flush. If you don't have it yet, you will…
Mine was totally fine (MY2013) until just recently. Might as well buy and install these clips before it happens to you!
jtiptonk is offline   Reply With Quote
Old 08-11-2020, 06:06 AM   #82
My 6 year old, 150,000 mile, lowered FRS, that bounced the bumper off any incline over about 20 degrees and many a speed bump was still 100% fine. In fact when I sold it one of the first things the guy said was "Hey, it doesn't have bumper gap".
theneptune86 (03-08-2021)
Old 10-03-2020, 04:02 PM   #83
jtiptonk
jtiptonk's Avatar
one of the lucky ones I guess!
and an update: I installed these and it still didnt fix it, so it must be the brackets
The Following User Says Thank You to jtiptonk For This Useful Post:
Tcoat (10-03-2020)
Old 03-07-2021, 03:18 PM   #84
macuser27
macuser27's Avatar
I have the dreaded bumper gap on my 2013 BRZ. I bought two of these metal pieces (57722CA030 - $11 each from the dealer) and new bumper brackets (57707CA050 & 57707CA040). The fix was successful for one day and now have the gap again. Is there no permanent solution?
macuser27 is offline   Reply With Quote
57722ca060 plate bmpr sd, brz, subaru, zc6
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 04:52 AM
SB17-067 Leakage countermeasure for VALVE ASSY OIL CTRL 2013-2017 Trap63 Issues | Warranty | Recalls / TSB 10 06-03-2018 11:33 PM
SB18-077 *BRZ ALL, Flywheel assy and ball bearing Trap63 Issues | Warranty | Recalls / TSB 0 05-29-2018 03:26 AM
Someone recognizes this rear spoiler? pepe Cosmetic Modification (Interior/Exterior/Lighting) 13 08-12-2016 05:57 AM
USB flash drive for mp3's, only recognizes 61 songs per folder? Suparu Electronics | Audio | NAV | Infotainment 6 08-22-2015 02:15 PM
