Old 06-03-2019, 09:58 PM   #15
toast
Drives: 14 BSP Edelbrock BRZ
Originally Posted by jflogerzi View Post
Communication and people's ability to form cohearhant sentences... I weap for humanity.. but as others said go to another Dyno
Sent from my ONEPLUS A5010 using Tapatalk
Seriously? You write some shit like that with a guy speaking a second language and then you misspell 'weep'?
toast is offline   Reply With Quote
The Following 6 Users Say Thank You to toast For This Useful Post:
86MLR (06-04-2019), 86TOYO2k17 (06-04-2019), B T (06-07-2019), DarkPira7e (06-06-2019), Irace86.2.0 (06-03-2019), Joesurf79 (06-06-2019)
Old 06-03-2019, 09:59 PM   #16
toast
And coherent...
The Following 5 Users Say Thank You to toast For This Useful Post:
86MLR (06-04-2019), 86TOYO2k17 (06-04-2019), DarkPira7e (06-06-2019), Irace86.2.0 (06-03-2019), Turbo (06-06-2019)
Old 06-03-2019, 11:18 PM   #17
KingJon1991
Drives: scion frs 2015
sounds like the tuner is doing a safe tune for you not to blow plus your still running oem fuel pump
KingJon1991 is offline   Reply With Quote
Old 06-04-2019, 04:52 AM   #18
86MLR
86MLR's Avatar
FAIL
Old 06-04-2019, 10:56 AM   #19
toast
You sure you're in dyno mode (ie pedal dance)?
Old 06-04-2019, 12:05 PM   #20
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
A fuel pump upgrade isn’t necessary. I’m running E85 at 12psi with 770cc injectors, and I have a Dw300c, yet the pump isn’t necessary; it was just an upgrade I did along with injectors, but the stock pump wasn’t close to its limits.
Old 06-04-2019, 12:27 PM   #21
Irace86.2.0
Unless the traction control came on then the pedal dance shouldn’t effect power. More of a safety thing. Just turning off traction control with the buttons is enough.
Old 06-04-2019, 01:06 PM   #22
toast
Ah, I thought all the nannies had to be off in order to have stationary front wheels and spinning rears.
Old 06-04-2019, 01:14 PM   #23
Irace86.2.0
If that was the case then burnouts would be impossible without the pedal dance.
Old 06-05-2019, 05:43 PM   #24
gt7877
Drives: turbo frs
At Saturday I'll try dyno jet and I'll c what well happen
I'll update u soon
Thank for all
gt7877 is offline   Reply With Quote
The Following User Says Thank You to gt7877 For This Useful Post:
86TOYO2k17 (06-05-2019)
Old 06-05-2019, 05:48 PM   #25
gt7877
Drives: turbo frs
Let him speak what he wants
I do not care about such people at all
my mother language is Arabic
English is the second language and I try hard to communicate in the best way with you
Old 06-05-2019, 07:03 PM   #26
86MLR
86MLR's Avatar
You're doing fine mate.
Some people are just idiots.
Run a 1/4 mile mate and post your MPH ET and the weight of your car with you in it.
Dynos are tuning tools, apps are toys.
Rock and Roll
The Following User Says Thank You to 86MLR For This Useful Post:
gt7877 (06-05-2019)
Old 06-06-2019, 12:35 AM   #27
Turbo
Drives: FR-S Turbo
I'll update u soon
Thank for all
Is there another dyno shop you can try? Perhaps one that uses a Dynapak dyno?
It would also be good to have the tuner map your AFR ratio and boost level to verify what numbers you're seeing there. I've also been told it can be a good idea to write down the calibration/setting parameters and also record the ambient temperature in the garage that day, but that might be overkill.
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
gt7877 (06-06-2019)
Old 06-06-2019, 08:49 AM   #28
86TOYO2k17
Drives: 2017 toyota 86
Thats what he said hes doing is testing on a different dyno. And the original dyno sheet shows 96 degrees.
But yes depending on calibration you can have ridiculously high or low numbers.
I'll update u soon
Thank for all
A few things to note, high ambient temps will decrease your numbers, and especially if he did numerous back to back runs and heat soaked the whole system. Also if you have a manual make sure he does it in 5th gear, if an auto its 4th gear any other gear will give an "off" reading, and make sure all nannies are turned off.
Also i don't see you mentioning octane? these cars having such high compression really benefit a lot from higher octane, or hurt a lot more from lower octane. you also live in a very hot climate year round. IF you have access to E85 i would make the switch ASAP, if not i would look into water meth, that will help a lot with keeping intake temps down and give you more power, but also give you more consistent less prone to heat soaking power.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
gt7877 (06-06-2019), Turbo (06-06-2019)
