Old 06-02-2019, 02:52 PM   #1
gt7877
Drives: turbo frs
Question dynocom hp??
Hi
I have tuned online my turbo FRS
The tuner told me to check how much hp now at the nearest
Dyno shop ??!!!
But after long tune back and forth from the tuner he told me he done
More update
195hp 🤔🤔 this is the result
How
gt7877 is offline   Reply With Quote
Old 06-02-2019, 03:10 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
How much boost/psi?
Old 06-02-2019, 03:33 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is that taken from a log file? Is that calculated torque from acceleration or from hp and tq values that the ECU outputs?
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-02-2019, 03:40 PM   #4
86TOYO2k17
Drives: 2017 toyota 86
From briefly reading other forums dynocoms typically read on the high side. 195whp on a turbo seems low for any dyno. Maybe if it’s only 7psi on pump with no other supporting mods and baseline was only 140whp then 195whp is a 40% increase.
Need more info on your setup, and did you baseline? Or at least know what other 86s baseline?
Old 06-02-2019, 03:48 PM   #5
gt7877
Drives: turbo frs
I bring it to the Dyno shop
There do one 4th gear pull to red line
And this is the result
I but 4+8 psi spring
Total 12psi
But how this could be 195
But at real driving i feel more power than this
My setup
Know off greedy turbo kit gt2871r
Dw720 cc
Emusa wastegate
Stock fuel pump
Online tune
Old 06-02-2019, 04:07 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Seems low to me.
Old 06-02-2019, 06:14 PM   #7
Lantanafrs2
Drives: 2013 frs red
Unless you're missing a cylinder, that dyno is screwy.
Lantanafrs2 is offline   Reply With Quote
Old 06-02-2019, 08:05 PM   #8
gt7877
Drives: turbo frs
What do u mean??
I think they screw me to let then tune it again 😂
Normal drive very powerful
But at the Dyno like stupid donky
Old 06-02-2019, 08:10 PM   #9
gt7877
Drives: turbo frs
But I don't know why
195@7000rpm
But the red line is 7800rpm!!
189@4900
Is it normal??
Old 06-02-2019, 08:23 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
There are a lot of parameters they could have goofed as well that could skew it badly. What elevation are you at?
Old 06-02-2019, 09:41 PM   #11
Irace86.2.0
195@7000rpm
189@4900
Is it normal??
The car can go to 7800rpms, but the redline is 7400rpms, and yet redline won’t be where peak power is being made, so there was no point in continuing the run past 7k.
I would confirm boost with a boost gauge. If you are at 12 psi, and the car is fast, and you still want to confirm on a dyno then try a different dyno or drag race the car.
Old 06-03-2019, 12:39 AM   #12
gt7877
Drives: turbo frs
My plan is to drag race
2off my friends FRS
Both I know the power
This well show me my correct car power
Old 06-03-2019, 09:37 PM   #13
jflogerzi
jflogerzi's Avatar
Communication and people's ability to form cohearhant sentences... I weap for humanity.. but as others said go to another Dyno
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 06-03-2019, 09:48 PM   #14
86TOYO2k17
The dudes from OMAN and speaks Arabic... obviously a second language he’s not very good at. Still easy to get the gist of what he’s trying to say.
