Old 06-01-2019, 12:27 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
E85 and engine internals
I searched for this but didn't find anything. Has anyone encountered degrading of fuel-system components running E85 and tune?
Qwimby1 is offline   Reply With Quote
Old 06-01-2019, 12:31 PM   #2
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Ive heard LOTS of people have been using E85 for tens of thousands of miles. I havent seen anything about the need to upgrade hoses or filters. If you go FI, youll need a pump and injectors depending on your goals.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Westen86 For This Useful Post:
Boris_Petrov (06-01-2019), DarkPira7e (06-01-2019), Lantanafrs2 (06-01-2019), Qwimby1 (06-01-2019)
Old 06-01-2019, 03:33 PM   #3
reeves
Na, you're good.. Go for it!
The Following User Says Thank You to reeves For This Useful Post:
Old 06-01-2019, 06:43 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Modern cars are pretty well designed for ethanol because gas has 10% ethanol, so it shouldn't be an issue. Most upgraded components are typically E85 safe like injectors or fuel pumps, but it is always good to confirm.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 06-01-2019, 10:48 PM   #5
Lantanafrs2
Drives: 2013 frs red
With recent geopolitical bullshit pressuring farmers, look for ethanol production to rise even as the crusty, old conservatives cling to their love of dinosaur bones and the companies that drill for them. Automotive fuel systems better be able to handle alcohol. All that corn has to go somewhere.
Lantanafrs2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
DaBoBo21 (06-02-2019), smg1138 (06-01-2019)
Old 06-01-2019, 11:20 PM   #6
BEZO760
Drives: Blue 2016 SCION FR-S
I have also been searching for an answer to this question and so far all I've found was reassurance that it is way too early to know for sure. But since bad news always travels alot faster than good news I feel confident that we should be fine. I haven't heard of an instance where running e85 was a direct cause of some kind of malfunction in our cars.
BEZO760 is offline   Reply With Quote
Old 06-01-2019, 11:52 PM   #7
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I’ve been running e85 in my FRS pretty regularly for about 4 years and haven’t had any issues. I once sent off an oil sample to Blackstone at 7,500 mi and they said it looked good and to try 9,500 miles the next time. So apparently oil contamination isn’t really an issue with e85 in this car. I sometimes run Shell 93 for long road trips and AutoX events which is probably good for the detergents.
smg1138 is offline   Reply With Quote
Old 06-01-2019, 11:55 PM   #8
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
all my wear metals were below average when i blackstoned it. i did have a higher % of fuel in my oil. i had about 1/2% and that lowered my flashpoint they said
Old 06-03-2019, 09:30 AM   #9
Qwimby1
I guess our collective experience puts the lie to the auto manufacturers threatening to pull warranties if the government approved 15% alcohol.
5
Old 06-03-2019, 11:08 AM   #10
Irace86.2.0
5
That’s different.
Old 06-04-2019, 12:14 PM   #11
Qwimby1
Yeah, in retrospect I see that.
Engine internals for 500-600 HP turbo Hags86 Forced Induction 52 11-05-2020 04:22 AM
Engine Internals from CP-Carrillo Now Available! Infamous Performance Engine, Exhaust, Bolt-Ons 108 02-13-2014 11:35 AM
THEY'RE HERE!! ENGINE INTERNALS // DSG PERFORMANCE Jason@DSG Engine, Exhaust, Bolt-Ons 18 01-14-2014 11:15 AM
Max power for factory drivetrain and engine internals solidONE Forced Induction 64 09-23-2013 01:16 PM
Engine internals before FI? Rejor11 Forced Induction 14 06-04-2013 05:18 PM
