Old 05-22-2019, 01:33 PM   #1
DenisSlob4
Salvage BRZ
Hello. I purchased a salvage 2013 BRZ, I think Limited as it has push to start. I don't get power to anything besides interior and trunk dome lights, door sensor doesn't work. My power locks don't work either. I was wondering if anyone knows what systems need to receive power for power locks and accessory power. Or how to start to diagnose this issue. Thank you.
DenisSlob4 is offline   Reply With Quote
Old 05-22-2019, 01:59 PM   #2
norcalpb
norcalpb's Avatar
Door lock actuator. It’s the motor that controls the locks going in and out.
Because the doors are so thin and non-insulated tons of grime gets built up in this device and it’ll stop functioning entirely.
Pretty easy install even for a beginner.
Old 05-23-2019, 11:35 AM   #3
maslin
Benz Tech
Drives: 2017 BRZ Premium
Step 1. You bought a salvage car dead in a parking lot without any idea of how to diagnose basic electrical issues?
Step 2. Google BRZ wiring diagram and dive in. Probably a prefuse blown by something major shorted, or separated by SRS? Not sure if these cars are that smart.
maslin is offline   Reply With Quote
The Following 2 Users Say Thank You to maslin For This Useful Post:
DarkPira7e (06-03-2019), Leonardo (05-23-2019)
Old 06-01-2019, 02:38 AM   #4
sokol
Drives: 2014 fr-s
1. check fuses.
2. check fuses again.
sokol is offline   Reply With Quote
Old 06-01-2019, 02:39 AM   #5
sokol
Drives: 2014 fr-s
Dennis you're in Sacramento, bring the car to my shop ill find what the problem is....
Old 06-03-2019, 05:26 PM   #6
DenisSlob4
1. Car looked in better condition then it was. I really wanted a BRZ so was kinda blinded by that. I can diagnose basic electrical issues but this seems more complex. Especially with the immobilizer system.
2. I pulled all fuses and relays and there were a few blown ones. I tested them and after confirming that the fuses and relays work, I cleaned them up and put them back.
3. I am asking for help as I am stuck. If you're one of the people who says to google or are judgmental, please do not reply to this thread. In fact do the world a service and don't reply to any thread. Just create your own. Thank you.
Old 06-03-2019, 05:49 PM   #7
extrashaky
Drives: 2014 BRZ Limited
You really need the factory service manuals.
You can download PDF versions from this thread:
http://www.ft86club.com/forums/showthread.php?t=8374
You can download the BD-ROM version from this thread:
https://www.ft86club.com/forums/showthread.php?t=35279
I have the BD-ROM saved as my F drive on my laptop. It has come in quite handy on several occasions.
Old 06-03-2019, 05:56 PM   #8
DenisSlob4
Thanks. If you don't want to share your info publicly, please pm me with location and cost /hr or whatever you charge for.
Also, so I believe this car was a rollover. However, the worst part is that someone at the auction ripped off the window protective stickers to take a look inside and it was raining then. When I got it, there was about an inch of water in the car. I didn't provide power since I got it prior to gutting and cleaning the whole thing. Including opening every module and cleaning it with isopropyl alcohol and brush.
https://imgur.com/a/BhLR9Xy
Old 06-03-2019, 05:58 PM   #9
https://demos.starbase7.net/t3Portal/
humfrz (06-03-2019), maslin (06-03-2019)
Old 06-03-2019, 06:28 PM   #10
maslin
Benz Tech
Are Kirkeys, an LS and Motech an option? Probably the easiest way to bring that back.
And I found your power issue. Everything is unplugged.
Seriously though. If that's the current condition, you aren't in a place to check anything. Assuming the car has been reassembled to a significant degree... Power and ground. Everywhere there should be power and ground. That's step one. After you've established constant and switched power, check CAN. From there, you're ruling out modules.
I watched a guy dump $80k in to a flood salvage S550. It left our shop the same way it came in, on a roll back. He had "disassembled and cleaned" the modules as well. They were all dead, along with the chassis harness. My $40k quote ran him out the door. He could have bought a nice running car for $50k at the time.
I suspect you will surpass the price of a running BRZ well before it ever moves and passes an inspection. Good luck, looks like a track toy to me at this point.
The Following User Says Thank You to maslin For This Useful Post:
Ultramaroon (06-03-2019)
Old 06-03-2019, 08:11 PM   #11
DenisSlob4
Thanks. I found some manuals, including the wiring diagram one which is kinda difficult to follow. The ISO one's link doesn't work anymore.
Old 06-03-2019, 08:20 PM   #12
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Oi, you came to the forum, the forum did not come to you. Don't forget that. Hopefully you are able to get a helpful answer, but as with any platform where someone can share an opinion openly, don't be surprised when they do.
I'd run a search on the VIN to find the exact options the car came with, as the modules and harness could vary significantly based on keyless vs keyed premium model.
Once you know which category it falls under, you can limit your wire hunting and run proper root cause hunt. It may not hurt to buy a harness from a known working car to eliminate shorts or missing pieces. Being a salvage car, someone could've jacked up that harness.
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
humfrz (06-03-2019), maslin (06-03-2019), spitsnaugle (06-03-2019), Ultramaroon (06-04-2019)
Old 06-03-2019, 08:30 PM   #13
DenisSlob4
Yea, I'm thinking of getting a donor car but don't have enough space for it.
As for the comment I made. I understand where you're coming from but when I read other people's threads it's annoying to see some random person messing up a good conversation with their random posts. Wastes everyone's time. And yes, I came to a car forum to talk about car issues and resolutions amongst people like myself, not to be judged by some random person. I have no problem with them starting their own thread to talk about things relevant to them.
Old 06-03-2019, 10:19 PM   #14
CoolHandMoss
Drives: 2013 FRS
It's the salvage FR-S that you need to be careful of. You should be fine with the BRZ.
CoolHandMoss is offline   Reply With Quote
From Salvage to Dream Car Dennett_ Member's Car Journals 26 11-15-2017 02:10 PM
WTB: Totaled or Salvage BRZ Bullitt2496 Want-To-Buy Requests 0 12-30-2016 08:30 PM
Buying salvage BRZ HubertK BRZ First-Gen (2012+) — General Topics 26 12-15-2016 04:15 PM
Looking for an FR-S/BRZ w/ a salvage title ProTekk Other Vehicles & General Automotive Discussions 1 05-05-2013 01:54 AM
brz salvage hunter3232792 BRZ First-Gen (2012+) — General Topics 4 10-13-2012 08:41 PM
