Old 05-31-2019, 07:06 PM   #8429
jflogerzi
jflogerzi's Avatar
Originally Posted by 86TOYO2k17 View Post
So he drilled and thread tapped the snout with it still on, got metal
shavings inside and now doesn’t have a supercharger anymore?
You can take snout off with leaving SC on manifold/installed to engine. Thread tap it and reinstall. Just sounds like a pain to do in order to fix something that may not even need fixing. Would be just a potential safety precaution.
Here is what he said. He did the install on my car. I trust him. He knows what he is doing
Combination of a really sharp drill bit that removes large chunks at a time instead of small shavings, and grease to trap it all. No pilot hole
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 05-31-2019, 07:13 PM   #8430
86TOYO2k17
Drives: 2017 toyota 86
That would be 10times easier, but way more risky. He’d still need a tap to thread it though. Don’t see how you could avoid small shavings with that.
I have a 1/8npt tap from tapping map plate and it was shave city.
Old 06-10-2019, 06:22 PM   #8431
kev0
Drives: '14
Would you guys ourchase the nonintercooled kit with 20k miles on it for $1500? How reliable would my engine be with this kit? More reliable than others since This kit is only 5 psi, right?
kev0 is offline   Reply With Quote
Old 06-10-2019, 06:38 PM   #8432
86TOYO2k17
Kit is generally pretty reliable even with smaller pulleys. Nonintercooled kit is only really recommended if you have E85 or WMI otherwise lots of heatsoak. But I believe the MAP sensor will actually read accurately without the intercooler heatsink causing turbulence issues.
I think 80mm pulley is about 5psi, 75mm 9psi 72.5 10.5psi 70mm 12psi
For 1500$ it’s pretty cheap. Might need a rebuild, could be why they selling so cheap though.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
kev0 (06-10-2019)
Old 06-10-2019, 06:40 PM   #8433
kev0
Drives: '14
Darn, okay. I wasn't planning on going E85. Guess I'll have to skip this kit and look for an intercooled one. Thanks a lot, man!
Old 06-10-2019, 07:11 PM   #8434
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I suppose I can't chime in, because it's my kit that you were looking to buy
I do agree with E85 -- I enjoy the kit a LOT more with E85 -- the pull is much stronger.
And the kit is in great shape (as far as I can tell -- No issues, and it doesn't burn through much oil) -- I just would like to make it an easy sale and I figured a nice price would help move it along.
ajcarson11 is offline   Reply With Quote
Old 06-10-2019, 07:22 PM   #8435
kev0
Drives: '14
Haha, didn't expect to see you here!! Now i'm interested again. A kit rebuild is only $700 anyways, if something is wrong with it. I just know for a fact that I won't be running E85 on my car. I'm not even worried about heat soaking, since I don't drive like a maniac. I'm just worried about my stock motor being blown
Old 06-10-2019, 07:33 PM   #8436
ajcarson11
There are never any guarantees with stock motors, but I can tell you that most of your risk lies in the tune. You are much safer with a tuner who understands this car and this kit -- I would go with Moto East or Delicious Tuning personally, for that reason alone. I've been very happy with my tune from Moto-East -- Mike really knows his stuff. They do great work in-house, and even his E-tune is used by hundreds of other Sprintex 210 drivers (it is what I have been using).
This kit doesn't make a boat-load of power, especially in comparison to other offerings out there -- Ultimately this reduces risk to your motor, clutch, etc. It is one of the main reasons I went with this setup -- I haven't had to worry about my engine being strained to the max by other kits, and I haven't had to upgrade fuel pump or injectors (which just add complications).
With all of that being said, if you're looking for a modest increase in power (add some fun) and a lot of cool/exciting whine (adds big fun!) then you'll like this kit. If you're interested in street racing it may be disappointing. The cost vs performance, the low-end torque for daily driving, and the whine are what made this kit stand out for me.
If you have E85 in the area you might do a bit of thinking on that -- A flexfuel kit would let you run any combination of E85 and normal gas (in case you have to fill up with normal fuel at times where E85 isn't available). The transition between fuels is seamless, and E85 is quite a bit cheaper (at least here in Indiana... $2.09 for E85 vs $3.50 for 93). With E85 the kit really wakes things up.
It's all about what you are looking for!
The Following User Says Thank You to ajcarson11 For This Useful Post:
kev0 (06-10-2019)
Old 06-10-2019, 09:27 PM   #8437
ls1ac
ls1ac's Avatar
I have one of the first 210's, with no intercooler. Have been using it for a DD and have tracked it quit a few times. Yes on a hot day it will heat soak, but that just means loss of power. If driving hard in hot weather I would recommend an oil cooler, I do not have one and watch oil temps carefully and use a good synthetic oil.
Delicious tuning has been very good.
It is not very fast but is much more fun than stock.
Old 06-10-2019, 09:52 PM   #8438
86TOYO2k17
Assuming you have a proper install and a good tune. It’s pretty unlikely the sprintex kit will be the cause of your engine blowing, especially on the 80-75mm pulley. But nothing is guaranteed.
The heatsoak isn’t necessarily dangerous. But after 1-2 hard high speed pulls you’re power will drop off quick and pull about the same as an NA with full bolt ons. For a pure DD it’s not the end of the world. You may be able to reach out to some vendors and find a intercooler upgrade kit. Or could get a WMI setup.
Most people who buy used send it out to Jon bond for inspection/rebuild and then it should be pretty much good as new.
Old 06-11-2019, 12:33 AM   #8439
kev0
Drives: '14
Very informational. Thanks. Would a hood with a hood scoop help with the heat soak? Not expecting it to work as good as an intercooler, but I should get a hood scoop to be safe, right?
Old 06-11-2019, 01:47 AM   #8440
86TOYO2k17
Couldn’t hurt. I’m sure it will help a little bit. Could also try a Perrin CAI and some gold reflective heat tape and wrap the sprintex intake pipe and the Perrin CAI with that. Those with the hood vent/scoop would help prolong the inevitable heat soak.
What hood scoop are you thinking about?
kev0 (06-11-2019)
Old 06-11-2019, 02:02 AM   #8441
kev0
Drives: '14
Looking at a Seibon FA-Style Hood
Thanks again for your assistance.
Old 06-11-2019, 04:18 AM   #8442
sqd
sqd's Avatar
Drives: '13 SWP GT86
Speaking of hoods, for anyone curious, the 210 works fine with the Varis Arising II version 2 hood that also has the NACA-duct. It diverts air to the back of the charger as well, should absolutely help with temps.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
The Following 4 Users Say Thank You to sqd For This Useful Post:
86TOYO2k17 (06-11-2019), jflogerzi (06-12-2019), new2subaru (06-13-2019), weederr33 (06-11-2019)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
