#8429 | |
Combination of a really sharp drill bit that removes large chunks at a time instead of small shavings, and grease to trap it all. No pilot hole Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
#8430 | |
Drives: 2017 toyota 86
I have a 1/8npt tap from tapping map plate and it was shave city. |
#8431 |
Drives: '14
Would you guys ourchase the nonintercooled kit with 20k miles on it for $1500? How reliable would my engine be with this kit? More reliable than others since This kit is only 5 psi, right?
#8432 | |
I think 80mm pulley is about 5psi, 75mm 9psi 72.5 10.5psi 70mm 12psi For 1500$ it’s pretty cheap. Might need a rebuild, could be why they selling so cheap though. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | kev0 (06-10-2019) |
#8433 | |
Drives: '14
#8434 | |
Drives: 2013 Subaru BRZ Limited (Black)
![]() I do agree with E85 -- I enjoy the kit a LOT more with E85 -- the pull is much stronger. And the kit is in great shape (as far as I can tell -- No issues, and it doesn't burn through much oil) -- I just would like to make it an easy sale and I figured a nice price would help move it along. |
#8435 | |
Drives: '14
#8436 | |
This kit doesn't make a boat-load of power, especially in comparison to other offerings out there -- Ultimately this reduces risk to your motor, clutch, etc. It is one of the main reasons I went with this setup -- I haven't had to worry about my engine being strained to the max by other kits, and I haven't had to upgrade fuel pump or injectors (which just add complications). With all of that being said, if you're looking for a modest increase in power (add some fun) and a lot of cool/exciting whine (adds big fun!) then you'll like this kit. If you're interested in street racing it may be disappointing. The cost vs performance, the low-end torque for daily driving, and the whine are what made this kit stand out for me. If you have E85 in the area you might do a bit of thinking on that -- A flexfuel kit would let you run any combination of E85 and normal gas (in case you have to fill up with normal fuel at times where E85 isn't available). The transition between fuels is seamless, and E85 is quite a bit cheaper (at least here in Indiana... $2.09 for E85 vs $3.50 for 93). With E85 the kit really wakes things up. It's all about what you are looking for! |
| The Following User Says Thank You to ajcarson11 For This Useful Post: | kev0 (06-10-2019) |
#8437 |
I have one of the first 210's, with no intercooler. Have been using it for a DD and have tracked it quit a few times. Yes on a hot day it will heat soak, but that just means loss of power. If driving hard in hot weather I would recommend an oil cooler, I do not have one and watch oil temps carefully and use a good synthetic oil.
Delicious tuning has been very good. It is not very fast but is much more fun than stock. |
#8438 | |
The heatsoak isn’t necessarily dangerous. But after 1-2 hard high speed pulls you’re power will drop off quick and pull about the same as an NA with full bolt ons. For a pure DD it’s not the end of the world. You may be able to reach out to some vendors and find a intercooler upgrade kit. Or could get a WMI setup. Most people who buy used send it out to Jon bond for inspection/rebuild and then it should be pretty much good as new. |
#8439 | |
Drives: '14
#8440 | |
What hood scoop are you thinking about? |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | kev0 (06-11-2019) |
#8441 | |
Drives: '14
Thanks again for your assistance. |
#8442 |
Drives: '13 SWP GT86
Speaking of hoods, for anyone curious, the 210 works fine with the Varis Arising II version 2 hood that also has the NACA-duct. It diverts air to the back of the charger as well, should absolutely help with temps.
IG @squareddesign
http://www.squareddesign.se |
| The Following 4 Users Say Thank You to sqd For This Useful Post: |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
