Old 04-09-2019, 10:52 AM   #155
HaXx
Drives: jrsc_brz
I bought a pair of second hand bajadesigns yellow fogs from heres my mind. 5 star seller rating.
Question, bc I like the fogs so much, I'dlike to have them on during "auto" and "parking light" settings. Currently fogs only light on lowbeam setting. I'm sure this has been asked before but this thread is massive! Forgive me
HaXx is offline   Reply With Quote
Old 04-09-2019, 11:02 AM   #156
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
There is a very simple harness you can hook up for that to work. I’ll send you details later dude!!
-B
HeresMyMind is offline   Reply With Quote
The Following User Says Thank You to HeresMyMind For This Useful Post:
HaXx (04-09-2019)
Old 04-09-2019, 04:31 PM   #157
HaXx
Drives: jrsc_brz
Awesome man, keep me posted about future used parts for sale as well
Old 04-11-2019, 03:39 PM   #158
Thedishdoc
Drives: 2015 Scion FRS
I've got a 2015 FRS that did not come with fog lights. If I get a set of Type S Morimoto XB LED fog lights, will they just plug into the existing harness or would they need to be wired up custom?
2015 Red FRS
Enkie LC5 18" Rims/Michelin 225-45 18 Super Sports
Perrin resonated catback exhaust
FT86 UEL catted header
Stage 2 OFT tune
Thedishdoc is offline   Reply With Quote
Old 04-11-2019, 04:58 PM   #159
mintyfresh
LA Bron
mintyfresh's Avatar
Drives: ‘15 WRB BRZ
How do I get those yellow fogs with greenish hue? Greens my favorite color
mintyfresh is offline   Reply With Quote
Old 04-11-2019, 06:36 PM   #160
HaXx
Drives: jrsc_brz
Look up chameleon fog lights, that what ur talking about? Subispeed has some. Def buy from heresmymind tho if he has anything, I've got stuff from him before, awesome.
The Following User Says Thank You to HaXx For This Useful Post:
mintyfresh (04-12-2019)
Old 04-11-2019, 11:01 PM   #161
Asphalt_15frs
Asphalt_15frs's Avatar
Drives: 2015 base frs
Having trouble with morimoto 2 stroke 2.0 led, on low,both arnt working. Tried flipping plug around, still nothing on both lights led plug that plugs into the h11 socket seems like it’s not connecting or the led both are crap. Any suggestions?
Asphalt_15frs is offline   Reply With Quote
Old 04-12-2019, 01:09 AM   #162
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
I have a 2013 and I had to wire up the harness for it.
Sent from my Pixel 2 XL using Tapatalk
Rican_D is offline   Reply With Quote
The Following User Says Thank You to Rican_D For This Useful Post:
Thedishdoc (04-12-2019)
Old 04-12-2019, 01:30 PM   #163
caffeinejunky
hella stock
caffeinejunky's Avatar
Drives: BRZ Limited
Do D4S bulbs in 3K exist?
mods & accessories:
beat-sonic shark fin | raceseng apex r limited green | perrin intake | E85 | RS*R Super Down sus | Cleib CF Lip | STi Side Skirts | Rays Gram Lights 57DR
caffeinejunky is offline   Reply With Quote
Old 05-30-2019, 09:32 AM   #164
HeresMyMind
Not that I know of. BUT you can install d2s bulbs in our head lights with minor modification of the bulb, or projector. and then swapping the ballast for a d2s ballast. there is ZERO difference in output.
-B
Old 05-30-2019, 09:33 AM   #165
HeresMyMind
The FRS should be pre wired. You would need the Fog Switch/Panel for the interior and a short 5-6" wire harness. The Fog Relay. and the plugs that go from the oem harness in the bumper to the Morimoto fogs.
-B
Old 05-30-2019, 09:34 AM   #166
HeresMyMind
Do you have an external power supply to check these out?
-B
Old 06-03-2019, 06:16 PM   #167
Rican_D
Rican_D's Avatar
-B
No, it wasn't pre wired. No OEM harnesses on the early FR-S. Trust me I bought a winjet fog kit and had to run the harness.
Sent from my ONEPLUS A6010 using Tapatalk
Old 06-03-2019, 06:18 PM   #168
HeresMyMind
Ah. I stand corrected! Maybe the US spec ones didn’t. I always assumed they did.
-B
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 03:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 08:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
