Old 05-29-2019, 02:04 PM   #15
qqzj
Drives: MDX, Camry
Originally Posted by HaXx View Post
Can u get rpf1 in the size ur looking for? That's pretty much the gold standard for light and strong wheels for small to mid wheels.
Not really. As you can see, this is my DD wheel. Don't want to spend too much. Wife is also getting impatient. She wants a new SUV for her. The request is not unreasonable because our current SUV is getting old. Cannot sell the old SUV either b/c it is reserved for daughter. So I might sell BRZ in near future. Don't want to put too much money now.
qqzj is offline   Reply With Quote
Old 05-29-2019, 02:10 PM   #16
Racecomp Engineering
They are $230 per wheel in 16x7 +35 which fits great and is super light. I have them on my car.
- Andrew
venturaII (05-29-2019)
Old 05-29-2019, 02:12 PM   #17
qqzj
Drives: MDX, Camry
Originally Posted by venturaII View Post
A 10mm spacer would push the wheels out to a more aesthetically pleasing location, but be sure to replace your studs with longer aftermarket ones to deal with the extra length needed.
Shouldn't 5mm spacer be closer to OE specs? Any link for such spacers and lug bolts?
This is getting more complicated. If I simply ignore the offset difference, what is the negative consequence? Wrong alignment? bad handling? Man, I really want those Australian OE 16 inch wheels.
The Following User Says Thank You to qqzj For This Useful Post:
why? (08-31-2019)
Old 05-29-2019, 03:01 PM   #18
qqzj
Drives: MDX, Camry
- Andrew
Thanks. So your wheel will poke out by 13mm each side. You don't need to do anything else and it won't cause any problems? That is great.
Old 05-29-2019, 03:08 PM   #19
new2subaru
Weight Weenie
Drives: 15 FR-S
Here, check out these calculators. It will help you visualize what can be done.
https://www.ft86motorsports.com/wheelitfit/
https://www.wheel-size.com/calc/
Tire rack has 81 to choose from in a 16x7 5x100 bolt pattern
https://www.tirerack.com/wheels/resu...5&autoModClar=
Just add the 205/55 R16 tires and you're done.
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
qqzj (05-29-2019), why? (05-30-2019)
Old 05-29-2019, 03:33 PM   #20
Looks like this (slightly lowered, but I had them at stock height too).
You don't need anything else.
- Andrew
Old 05-29-2019, 03:42 PM   #21
qqzj
Drives: MDX, Camry
I looked around on tire rack. This is the best wheel for this size. Looks really nice too.
- Andrew
Old 05-29-2019, 04:01 PM   #22
HaXx
Drives: jrsc_brz
If you want cheaper than rpf1, i like enkei ekm3. $165 a wheel in 17x7. It's a bbs LM knockoff. Ekm3 are my winters. 18x8 for summer.
HaXx is offline   Reply With Quote
Old 05-30-2019, 03:15 AM   #23
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
I use my BRZ for DD. Some of the roads I travel daily have bad pavement. So I am looking for a bit more ride comfort and possibly lighter weight.
I did the same thing for the same reasons.
Cost, weight, ride quality, and aesthetics were my
priorities. I went with the Konig Oversteer in 16" x 7.5"
They're not crazy light or glamorous but I still like them.
NWFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to NWFRS For This Useful Post:
qqzj (05-30-2019), venturaII (05-30-2019)
Old 05-30-2019, 11:21 AM   #24
I'll be selling my Enkeis with Blizzaks soon btw...
- Andrew
Old 05-30-2019, 11:41 AM   #25
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
These seem like the best value out there for 16's...lighter than OEM, perfect width for a 225/50 tire, good looking, and affordable.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
NWFRS (05-30-2019)
Old 05-30-2019, 02:45 PM   #26
DarkSideFRS
Drives: 2013 pearl white FR-S
If you wanna go rare OEM look, go with these Subaru wheels. It's not easy to find, but pretty nice looking.
whoa... what's with all that tape??? track day?
DarkSideFRS is offline   Reply With Quote
Old 05-30-2019, 03:01 PM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
autox i guess. Simple mod to protect paint from cones.
Old 05-30-2019, 03:02 PM   #28
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
That's my guess as well. I just found that on Wheel Directory.
Recommend for me a good bad tyre :P Ganthrithor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-14-2019 05:23 PM
Recommend any good auto shops? mick86 Arizona 3 08-11-2016 12:19 AM
Recommend me some cheap & good gloves Hanakuso Tracking / Autocross / HPDE / Drifting 24 01-02-2013 08:50 PM
Recommend a good tire shop in LA/OC Hanakuso Southern California 10 12-08-2012 06:15 PM
Can anyone recommend a good body shop? deucethemoose Northwest 14 11-02-2012 09:09 PM
