Old 05-28-2019, 05:25 PM   #1
qqzj
Drives: MDX, Camry
Anyone can recommend a good 16 inch wheel?
I use my BRZ for DD. Some of the roads I travel daily have bad pavement. So I am looking for a bit more ride comfort and possibly lighter weight. Probably first time visit this section of the forum, so excuse me if I missed anything.
Ideally, I can just put the wheels on and get 215 60 R16 tires and go. But if there are any other ideas, please let me know. Thanks!
qqzj is offline   Reply With Quote
Old 05-28-2019, 05:41 PM   #2
maslin
Benz Tech
Drives: 2017 BRZ Premium
215/50R16 is going to be a lot closer to stock, 60 aspect ratio will be tall.
There's a handful of 16s on the wheel fitment charts. Sticky at the top of this section.
215/50 is slightly shorter than stock, 225/50 or 205/55 are slightly taller.
maslin is offline   Reply With Quote
The Following 2 Users Say Thank You to maslin For This Useful Post:
qqzj (05-29-2019), why? (05-29-2019)
Old 05-28-2019, 05:46 PM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
Here's a good read for you
http://www.ft86club.com/forums/showthread.php?t=27023
What is your budget? I run 225/50 R16 on street (Looks) and 205/55 R16 on track. The 205/55 R16 is perfect IMO.
The Following User Says Thank You to new2subaru For This Useful Post:
why? (05-29-2019)
Old 05-28-2019, 09:09 PM   #4
gravitylover
The old WRX wheels were 16's and fit great. You can usually find them very affordably. They are a bit narrow at 7" for 225's but will be perfect with 205's.
The Following User Says Thank You to gravitylover For This Useful Post:
why? (05-29-2019)
Old 05-28-2019, 09:16 PM   #5
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
If you wanna go rare OEM look, go with these Subaru wheels. It's not easy to find, but pretty nice looking.
why? (05-29-2019)
Old 05-28-2019, 10:19 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I run a 16" Motegi MR116 for my winter tires. They've been through hell and are still in perfect shape. I run a 205/55r16 on them
qqzj (05-29-2019)
Old 05-29-2019, 12:32 AM   #7
qqzj
Drives: MDX, Camry
Man, that is long thread! Thanks a lot though.
Old 05-29-2019, 12:35 AM   #8
qqzj
Drives: MDX, Camry
I think the best choice is to get some old WRX wheels. Polish them up a bit and paint them bronze or gold. Let me check out my local craigslist. Ebay is too expensive.
Old 05-29-2019, 05:48 AM   #9
new2subaru
Weight Weenie
Drives: 15 FR-S
Meh, it's not that bad. I think I've been through it 3 times!
Old 05-29-2019, 07:17 AM   #10
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
i have 205/55 on 16" Sparco's, which you can get from tirerack for about $100 a wheel.
The old school gold RS wheels are the pinnacle, but good luck finding them. Pretty much every old Subaru 16" wheel will fit, and if you want to switch brakes to the WRX 4 pots every Subaru wheel in reasonably recent vintage will fit.
why? is offline   Reply With Quote
Old 05-29-2019, 08:53 AM   #11
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Tons of lightweight (relative to the OEM 20+ pound 17" wheels) aftermarket 16x7 wheels from places like TireRack, where they also make sure the offset isn't too far off from OEM. The base '86 in the rest of the world uses 205/55 R16, so it's not like that size tire isn't meant for the car... I use 205/55 in the winter, and 225/50 in the summer...both work wonderfully.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 2 Users Say Thank You to venturaII For This Useful Post:
maslin (05-29-2019), why? (05-30-2019)
Old 05-29-2019, 12:47 PM   #12
qqzj
Drives: MDX, Camry
Those old WRX wheels have offset like 53 or 55. What should I do to deal with the difference? The OEM offset is 48, right?
Old 05-29-2019, 12:55 PM   #13
venturaII
venturaII's Avatar
A 10mm spacer would push the wheels out to a more aesthetically pleasing location, but be sure to replace your studs with longer aftermarket ones to deal with the extra length needed.
Old 05-29-2019, 01:01 PM   #14
HaXx
Drives: jrsc_brz
Can u get rpf1 in the size ur looking for? That's pretty much the gold standard for light and strong wheels for small to mid wheels.
HaXx is offline   Reply With Quote
Recommend for me a good bad tyre :P Ganthrithor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-14-2019 04:23 PM
Recommend any good auto shops? mick86 Arizona 3 08-10-2016 11:19 PM
Recommend me some cheap & good gloves Hanakuso Tracking / Autocross / HPDE / Drifting 24 01-02-2013 07:50 PM
Recommend a good tire shop in LA/OC Hanakuso Southern California 10 12-08-2012 05:15 PM
Can anyone recommend a good body shop? deucethemoose Northwest 14 11-02-2012 08:09 PM
