#939 | |
Drives: FR-S,GTI
As far as speeding up "the inevitable", a few people have done autocrosses after the recall. You do a couple of those and the car doesn't blow up then you'll probably be alright. |
| The Following User Says Thank You to WNDSRFR For This Useful Post: | humfrz (05-28-2019) |
#940 |
Drives: 13' Lightning Red Brz
Just moving this from the registry thread.
Originally Posted by MuseChaser View Post Well, I guess it's time to post what I HOPE is a final update on my car and the four month saga... VERY short recap - Since about 60K miles, when I had the plugs replaced (recommended maintenance) and the timing chain cover resealed (warranty), slight reduction in gas mileage and power. Four months ago, had recall done. 500 miles later, checked oil... none visible. Overfilled accidentally, drained a quart, and noticed serious shrapnel in the oil. Another 100 miles, car starts hesitating, stumbling, backfiring, and smoking like crazy upon startup, a little over a month after the recall procedure Back to dealership, and they agreed to do a full engine replacement under warranty; master tech and I examined obviously worn and shot bearings and journals. Master tech informs me that someone had been inside my engine before, as he noticed sealant and shrapnel in the oil pan when he performed the recall, but neglected to mention it at the time hoping that it would be OK. I informed him the only other time any one had been "in the engine" was when it was at this same dealership for the timing cover reseal. He confirmed, but said he didn't do that reseal; it was one of the other guys in his crew. That's where the trouble started, and why he went out of his way to make sure I got a new engine. Much appreciated, but would have rather everyone been completely up front about that from the onset. As a thank you, and just preventatively, I also had them install a new clutch and TOB at my expense along with the new engine; they were very fair about the parts cost and didn't charge any labor. Another month goes by, get call, car is ready. Go pick it up. Check engine light comes on the next day, and car sounds like a loud sewing machine. Immediately back to shop. Code shows mixture problems and misfire (cylinder 3, I think). I asked whether they had changed the injector seals. "No, they didn't come with the recall or engine replacement parts list." They proceded to swap out injectors as part of their troubleshooting procedures, without replacing seals. I insisted that they replace the seals after they figure out what's wrong and prior to returning the car to me. They agree. More than another month goes by. Tech could NOT figure out why the car was running poorly. I finally get a call saying car is ready last week, and I've been driving it. It's running GREAT. The answer? The tech was at his wit's end, so he called Subaru and spoke with one of their engineers, describing the problem. The Subaru guy said to him, "You're really fussy, aren't you, and very careful?" The tech answered in the affirmative. Engineer told him that he has the valves shimmed to tight, and that these engines like to be adjusted to the middle of the allowed range rather than to the tightest tolerance. He reshimmed the valves for the fourth time, taking this advice into account, and the car runs awesome. Soooo.. that's the story. Not thrilled with the four months without my car, but can't fault the service manager or master tech for much.. they took good care of me. That's the tale. This now makes me curious. I have the sewing machine ticking noise from anywhere around 2.5k rpm and up and i’ve been told it’s my hpfp working and it’s normal. Except if it’s normal why did i start noticing it after the recall work was done and not before. |
#941 | |
humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (05-28-2019) |
#942 | |
#943 |
Drives: car
@Ichima check TSB 02-151-14R https://static.nhtsa.gov/odi/tsbs/20...84247-0699.pdf
This bulletin announces the availability of revised valve train components developed to reduce a tapping sound (sometimes described as “a sewing machine type” sound) which may be heard coming from the left-hand (B2) side of the engine when the engine is warm. This bulletin does not address any cold engine or start-up sounds. The changes consist of: • Design change to the valve rockers • Camshaft profile change • 1.65mm longer intake and 2.47mm longer exhaust valve stem lengths |
| The Following User Says Thank You to radroach For This Useful Post: | humfrz (05-28-2019) |
#944 | |
humfrz |
#945 |
okay, i'll keep listening to see if i hear anything else in regards to this. But overall, the car has been driving fine and 100miles later no more check engine light.
| The Following User Says Thank You to Ichima For This Useful Post: | humfrz (05-28-2019) |
#946 |
Drives: CBS BRZ Limited 6MT
Just dropped mine off at Faulkner Subaru in Harrisburg, here's hoping no surprises on 500 miles.
Also, I hate lane departure assist. Nothing more unnerving than the Ascent loaner turning the wheel FOR YOU.
Back in (Crystal) Black.
#947 | |
#948 |
Drives: car
I tend to think a good sewing machine sounds kinda smooth. It's how I described a honda cub passport I rebuilt.
Reminder that these 86 cars idle sound is like a tractor even from the factory. |
#949 |
Reported my engine failure after the recall to Toronto Star's Consumer Protection Reporter to try and bring more light on this situation. She said she is interested story but is hoping to hear from other affected Canadians. I've put her email address below if other Canadians wish to reach out.
eroseman@thestar.ca |
#950 |
Drives: 2013 Firestorm FR-S AT
So @humfrz have you come to a decision yet to have the valve spring recall done on your FR-S or are you still on the fence?
Given the odds of a spring fracturing versus my local Toyota dealer f*king up my perfectly running engine I'm not having it done. |
| The Following User Says Thank You to RickyBobby For This Useful Post: | humfrz (06-05-2019) |
#951 | |
Of course, by that time I'll be 80 some years old and I don't know if they will allow me to keep my FR-S with me, down at the Old Soldiers Home in Orting - ![]() ![]() humfrz |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#952 |
Dismember
Drives: 2013 Red Scion FR-S
Mine is still going strong, damnit!
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
