| AUSTRALIA Australia and New Zealand |
#29 | |
Drives: Civic Si coupe
I can't tell from the picture |
#30 | |
Drives: Honda Fit
If it shifts with difficulty when cold, then shifts better when warm, that could be normal. The gearbox oil works better when it is up to temperature. If you had no oil at all in the gearbox, the it should shift hard all the time, hot or cold. Can't comment on your petrol spills. |
#31 | |
Drives: Toyota 86 GTS & Mazda 3 SP23
at 1000kms now and the gear shift (auto) is much smoother, brakes are not so clunky and handles heaps better. |
| The Following User Says Thank You to UnLeasHer For This Useful Post: | JiB (07-10-2012) |
#32 | |
86 Owner
Drives: White GTS 86
No issues with gear box, though once or twice first didn't seem like it was fully engaged so just double pumped the clutch and all was good.
On the road. Check your mirrors! |
#33 | |
Drives: Honda Fit
If 1 and 2 have triple synchros, as some have stated, it can feel that way. |
#34 |
Drives: JDM86
The gearbox seems to be fine, probably just that cold weather we had.
Im going to fill up at a different servo this time. |
#35 |
try not sticking the noozel in all the way. it clicked over at 20 litres for me, so i pulled the noozel back slightly and no probs from then.
#36 |
Global Tactics Director
Drives: TRD,HRC
any splashback from the filler neck will always cause it to click off because it thinks its full.
#37 | |
Pegasus White
Drives: 86
Damn this this feels amazing now, not just getting locked out of the gear dosen't happen at all (cold or warm!) but no crunching noises at all! Said it was viscosity issue. Used some Subaru trans oil apparently(could get the oil wight out of him )
Driving: Pegasus White Manual GTS 86.
| The Following User Says Thank You to DriftEightSix For This Useful Post: | Marrk (07-17-2012) |
#38 |
Drives: Honda Fit
^^I imagine that, as time goes by, we will get a sense of which transmission oil works best in the car. Oftentimes, the OEM product works best; in some cases, an alternative from a quality manufacturer works better.
#39 |
Retail Sales Manager
Drives: Ducati Sport 1000 Harley Nightster
This is an interesting topic. On my MY07 WRX STi, with the DCCD, I had a LOT of clunking when going around slow speed turns (ie, car park).
A lot of reading on the nasioc forums in the usa led me to choose a different diff oil. In the end I went with Motylgear 75W90 Gear oil and magically, all the clunking stopped. Maybe trying different trans fluid may help with the cold shifting... |
#40 | |
Pegasus White
Drives: 86
#41 |
Drives: 2011 Corolla Ascent Sport
In that case they've gone from 75W90 to 75W90. That said, there are different types (containing different levels of anti-wear product) and not all can be used on all types of transmissions. See API ratings here.
#42 | |
Drives: 2jz
It was very hard to engage 1st gear in the morning and the shifting was not very pleasant . Did some research and decided to try Royal Purple gearbox oil and let me tell it changed the whole driving experience. It was the best thing ever, silky smooth gear changes... was brilliant. Back in the day I used order it from the USA but I know for a fact burson automotive is importing this product in Australia. Not sure if it is suited for 86 but its definitely better than toyota oil in my opinion. |
| Early problems - speaker rasp and long turnover | Hawaiian | Issues | Warranty | Recalls / TSB | 44 | 08-30-2013 04:39 PM |
| Problems with detailing | Nezz | AUSTRALIA | 23 | 06-28-2012 09:08 AM |
| Forum Problems | TRD-X | Site Announcements / Questions / Issues | 2 | 05-29-2012 10:45 AM |
| Do you think this car is going to have some problems? | Huss | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-21-2012 01:48 PM |
| What can we do? (RE: dealership problems) | D4ng3r | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 02-03-2012 10:36 AM |
