Old 05-27-2019, 04:18 AM   #43
WC-BRZ
Drives: Black BRZ
Originally Posted by j_ros94 View Post
Install and tune: $5,200
Sent from my SM-G960W using Tapatalk
Jesus christ...the rest of the stuff seemed within range...but $5,200 for installation labour and tuning?
What in the actual f*ck?
WC-BRZ is offline   Reply With Quote
Old 05-28-2019, 04:41 PM   #44
CSG Mike
CSG Mike's Avatar
Heres my dyno chart
Very solid numbers!
Sasha is a boss.
Old 05-28-2019, 04:42 PM   #45
j_ros94
Drives: 2017 Subaru BRZ
Very solid numbers!
Sasha is a boss.
He is lol
Im getting a flutter in the wastegate is that normal with the greddy kit?
j_ros94 is offline   Reply With Quote
Old 05-28-2019, 04:46 PM   #46
CSG Mike
CSG Mike's Avatar
He is lol
Unless you put in a BOV, yes, off-throttle compressor surge is normal.
This is my car with the same kit.
[ame]https://www.youtube.com/watch?v=RsyebKevv80[/ame]
Evil Rocky (07-08-2019)
Old 05-29-2019, 01:29 PM   #47
Turbo
Drives: FR-S Turbo
Anyone have specs on the turbo included in the T518Z setup?
I'm looking for wheel diameters, compressor and turbine A/R ratios.
Turbo is offline   Reply With Quote
Old 05-29-2019, 01:30 PM   #48
j_ros94
Weird im still getting a flutter even with a bov
Old 05-29-2019, 03:17 PM   #49
Turbo
Drives: FR-S Turbo
Wastegate flutter or compressor surge?
My boosted install originally had a TiAL Q50 BOV. It wouldn't blow off quickly enough or at lower pressures so I still had a bit of chirping.
Old 05-29-2019, 03:18 PM   #50
j_ros94
I hear the bov and a flutter
Old 05-29-2019, 04:37 PM   #51
CSG Mike
CSG Mike's Avatar
That's a problem. Make your BOV open earlier.
Old 05-29-2019, 04:39 PM   #52
j_ros94
That by a tune or mechanic?
The Following User Says Thank You to j_ros94 For This Useful Post:
CSG Mike (05-29-2019)
Old 05-29-2019, 05:36 PM   #53
Turbo
Drives: FR-S Turbo
If it's a BOV controlled solely by manifold pressure, I think it would mean adjustment of the BOV itself and perhaps changing the springs in it.
What BOV are you running? My car came with a TiAL Q50, but it wasn't opening fast enough or "blowing off" at lower boost levels. I changed springs to the absolute lightest one that would still keep the valve closed at idle (needed a bit of shimming) but it didn't solve the problem 100%
So- In the end, I went to a Greddy FV style BOV which seemed to be a vastly superior design (response wise) for applications that don't need to support massive levels of airflow.
Hope this helps.
The Following 2 Users Say Thank You to Turbo For This Useful Post:
CSG Mike (05-29-2019), j_ros94 (05-29-2019)
Old 05-29-2019, 05:40 PM   #54
j_ros94
Hope this helps.
Running tial QR with a 10psi spring so maybe i need a lighter spring
Old 05-29-2019, 09:57 PM   #55
Turbo
Drives: FR-S Turbo
The Q and QR and essentially identical. And my experience with the Q was it could not be made to work in such a low-flow application. According to TiAL tech suppoirt they are designed for 1000-1500HP applications.
They told me flat out it was the wrong BOV for my application. Said to use a QRJ, which is designed for smaller applications like ours. Problem is - the QRJ isn't supported in Canada, so getting replacement springs would take forever.
In the mean time, I checked out a Greddy FV on a friend's car, found it to be a far superior design for my application bought one and never looked back. Just be careful of counterfeits - or if you knowingly buy one make sure it's priced accordingly. If you go the QRJ route, be aware they use a completely different set of springs. And just like in the Q/QR you pick the spring rate according to the amount of vaccuum you pull at idle with all accessories off.
Good luck - hope it all works out for you.
Old 05-29-2019, 09:59 PM   #56
j_ros94
Will swap bov thanks
Will i need a retune?
GReddy T518Z Turbo Kit Richytort Engine, Exhaust, Bolt-Ons 4 09-01-2017 01:39 AM
FS: GReddy T518Z Turbo Jefffrs Engine, Exhaust, Bolt-Ons 2 08-15-2014 12:08 PM
BRZ GReddy t518z NOTORIOUS.BRZ BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-15-2014 02:15 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 06:09 PM
