Old 05-13-2019, 06:47 PM   #1
hestekinj
Drives: 2014 BRZ - WRB
Konig Dekagram 17x8 +40
Noticed there weren't too many photos available of the Dekagrams on the brz so I thought I'd upload a few photos. They are 17x8 +40 on stock suspension. Tires are Continental Extreme contact sport 225 45r17. Konig lists the wheels as 16.83lbs. Let me know if you have any questions!
hestekinj is offline   Reply With Quote
The Following 8 Users Say Thank You to hestekinj For This Useful Post:
Clutch Dog (05-14-2019), conehead (06-27-2019), korhun (06-17-2019), MCTeeJ (08-20-2019), mrg666 (10-12-2019), NWFRS (06-05-2019), phm14 (04-18-2020), qqzj (06-06-2019)
Old 05-13-2019, 06:51 PM   #2
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
The wheels and tires look great!
Now she just needs a drop!
eastendraceshop is offline   Reply With Quote
Old 05-13-2019, 07:33 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Those Konigs look nice on your BRZ. There really isn't a better deal on decently lightweight wheels!
I LIKE TIRES!
Old 05-13-2019, 10:15 PM   #4
hestekinj
True! That's the next major purchase in addition to a flex fuel sensor/tune!
The Following User Says Thank You to hestekinj For This Useful Post:
eastendraceshop (05-14-2019)
Old 05-13-2019, 10:16 PM   #5
hestekinj
Agreed! I love the look of them, they're lightweight, affordable and from a reputable brand. That's a tough combo to find!
Old 05-14-2019, 03:49 PM   #6
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Im a huge fan of the movement Konig has been working on, they've really pushed to get their name out there, and I like em a lot. Ill probably get a 17x8 when the time comes for really sticky rubber, ill retire my 18x8 to street duty
Clutch Dog is offline   Reply With Quote
Old 05-27-2019, 05:41 PM   #7
warhawk03
Drives: 2018 BRZ
Konig lists these at 16.83 lbs, did you get a chance to weigh them before mounting to see how close the specs are? I'm curious if these would meet the SCCA Solo Spec Coupe rules. 17 lb minimum for a 17x8.
warhawk03 is offline   Reply With Quote
Old 05-27-2019, 10:41 PM   #8
Buteo
Drives: Jeep 75th, Porsche GT3RS, BRZ tS
Will these clear the brembo brakes from the performance package?
Buteo is offline   Reply With Quote
Old 06-06-2019, 02:53 PM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Sadly, Konig Dekagram 17x8 +40 will NOT clear BRZ Performance Package Brembos.
It will touch the edge of the caliper that's closest to the hub.
See the black scratch from the wheel on the caliper on the photo below.
A 3mm spacer might be enough, but I didn't have one to try, and I personally don't want to use spacers.
The Following User Says Thank You to timurrrr For This Useful Post:
phm14 (05-01-2020)
Old 06-16-2019, 10:51 PM   #10
Brock H.
Drives: 2022 BRZ, Red
Any chance to see if these wheels will clear the AP Sprint BBK?
Brock H. is offline   Reply With Quote
Old 08-19-2019, 07:03 PM   #11
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
This size looks so good on stock suspension. I’m sure it would look even better with a minimal drop. Do you, or anyone else, have more pictures of this wheel on the car? I’m really debating between 9 and 8 width for this wheel. I’d really like the 8s for weight savings and 225 tires, but I don’t want the face to change like with RPF1s. Thanks
Will BRZ is offline   Reply With Quote
Old 08-20-2019, 09:31 AM   #12
Vital
Drives: 2015 BRZ
So, i have this wheel in 17x8 on 245/40/17 and lowered on RCE Yellows. I think it looks great and very OEM+ and functional. If i had do it again i'd just go 17x9 because with the 8" wheel rear with the drop it is slightly sunk in. Regardless i still love the way it looks. I can try to get you pictures later.
The Following User Says Thank You to Vital For This Useful Post:
Leonardo (08-20-2019)
Old 08-20-2019, 10:42 AM   #13
Will BRZ
Drives: 2015 BRZ
Yeah pictures would be great because Im going for a similar setup thanks. I just feel like the 9s would poke a little bit. I’d rather it be sunken in a bit than to poke
Old 08-20-2019, 11:33 AM   #14
Vital
Drives: 2015 BRZ
It'll definitely poke if you stay stock and it'll look bad too massive 4x4 status lol. The problem with 9" and stock struts up front is that its too close to the spring perch. The rears will have no issue of course. Now, you remedy the poke by adding camber, but i honestly dont think you'll be able to run much camber if any with that size wheel, tire, and that offset. If you are thinking about lowering definitely get some camber bolts for the front though.
timurrrr (08-20-2019)
18x9.5 +35 Konig Dekagram (Squared) adelbertray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 08-20-2019 10:19 PM
Konig Dekagram 17x9 18BrzBlue Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-02-2019 04:20 PM
Should I get 17x9 w 40 off or 18x8.5 w 44 off both konig dekagram Bread1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 01-26-2018 12:26 PM
Konig Hypergram 17x8 +40 TheMOPs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 06-18-2017 11:03 AM
FS: 17x8 Konig Runaway w/ 225/45/17 Continental Tire racing slicks LI/NY st0k3d Wheels and Tires 11 09-21-2014 11:19 AM
