Old 05-21-2019, 10:35 PM   #15
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Honestly, based on how that stack is, I can only blame heatsoak from the headers superheating your oil pan. The thermostat would only affect this negatively if it's opening late/not at all, if it's open all the time then that just says the oil cooler is not enough for your application.
I wish I had more to add, talk to the engine builder and see what they think. May be time to rent a flir camera and get to researching where the heat is coming from.
Old 05-23-2019, 07:13 PM   #16
thinkV
Drives: BRZ Turbo
Originally Posted by ZZT86 View Post
^^ speak to your engine builder but I suspect your turbo would be partly to blame as it's heating the oil especially after a good hard run. When you stop & idle there would be plenty heat soak under the bonnet driving temps up.
Personally I would have ceramic coated the turbo & exhaust manifold inside & out to keep under bonnet temps down. Why the oil restriction ?
This story reminds me of Colin McRaes adventures when he was in the WRC . . . . if he didn't stack it he would often eventually cook his Subaru - Be careful of that oil temp !
I think testing is done in a pot with a thermometer, slowing heating & you should be able to notice the thermostat change position - notice the temp this happens.
ps: I'm in Vic also - cool nights
What do you mean by "why the oil restriction?", and yes I plan to at least try and have my pipes wrapped soon. Is the cost much more to have them coated?
Hmm will have to try the thermostat testing, not sure I have it in me to take it all out and start again, need to find a quiet weekend.
Awesome, we should go fora drive!
Thanks! Guess I will try and wrap to see if it makes a big difference.
thinkV is offline   Reply With Quote
Old 05-23-2019, 08:05 PM   #17
jflogerzi
jflogerzi's Avatar
I would try and go for a coat rather than a wrap for safety just in case of oil leak
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 05-23-2019, 10:38 PM   #18
ZZT86
ZZT86's Avatar
Drives: BR86
@thinkV I have the TC1 coat on my header which is excellent http://www.hpcoatings.com.au/coatings-2/
You mentioned that your engine builder has locked you in to using Valvoline - why ?
ps: got a feeling my thermostat in the engine is playing up - bugger.
ZZT86 is offline   Reply With Quote
Old 05-24-2019, 09:55 AM   #19
wparsons
wparsons's Avatar
For the question about bleeding the oil cooler, any thermostatic plates I've seen are never fully closed to prevent the need for bleeding. They'll always flow a little bit of oil through the cooler, even when super cold.
flickr
jcw99 (05-25-2019)
Old 05-25-2019, 08:12 PM   #20
thinkV
Drives: BRZ Turbo
Just because it’s what they use and there’s technically a one year warranty on failure due to build.
But i guess that’s probably irrelevant now.
On a side note, my coolant temps sit at 100c all the time too, I thought this was normal.
Old 05-27-2019, 08:09 PM   #21
thinkV
Drives: BRZ Turbo
Booked in to get my headers, downpipe and overpipe coated next week in TBC1, hopefully that helps.
The Following User Says Thank You to thinkV For This Useful Post:
ZZT86 (05-29-2019)
Old 05-27-2019, 11:07 PM   #22
86MLR
86MLR's Avatar
Inside and outside?, if its only outside it's a waste of time IMO.
I was quoted $400 for my 86 headers inside and out, I ended up wrapping, LOL.
What are yours costing?
I've used exhaust wrap and turbo beanies forever though, never once had any issues.
A turbo manifold I had coated year ago ended up peeling after about 3 months, make sure you get a warranty.
Buy a infrared temp gun, you can pick them up for around $100.
Should help you track your temps.
Infrared heat guns are really usefull for multiple things anyway, a great asset to your tool box.
Old 05-30-2019, 09:22 AM   #23
ETM_Shaman
ETM_Shaman's Avatar
Drives: 2013 Toyota GT86
Have you noticed if your temps go up when NOT using a/c?
The stock tune turns the fans on at hotter temps when not using a/c than when using a/c. This will affect your oil temps if sitting long in traffic.
You can read about it here:
http://www.ft86club.com/forums/showthread.php?t=64731
You can change that easily with the tune. Nothing to worry about though, my oil cooler also heat soaks a little when sitting in traffic. It's oil temps under load that you should be worried about.
ETM_Shaman is offline   Reply With Quote
Old 06-02-2019, 08:42 PM   #24
thinkV
Drives: BRZ Turbo
Oh my god lol, I NEVER have my AC on. And my car has just gone off to get coated haha. I will ask my tuner.
Old 07-07-2019, 07:38 PM   #25
thinkV
Drives: BRZ Turbo
So an update, all headers, downpipe, overpipe are coated with HPC turbo coating. I think the temps dropped maybe 1-2 degrees.
I have also noticed that my Prosport gauge (sensor on the TRD sandwhich plate below the oil cooler sandwich plate on the stack) is reading much higher than my ECU reading.
In traffic conditions (bumper to bumper) With AC on:
ECU: 99c oil, 90c water
Prosport Gauge: 105c oil
In traffic with AC off:
ECU: 102c, 100c water
Prosport: 108-110c
It was 13c outside this morning when I drove.
Does this seem high?
Screenshots of the ECU reading:
ac on: https://i.imgur.com/ZkJCcl1.jpg
ac off: https://i.imgur.com/EHUkZU8.jpg
Old 07-07-2019, 08:53 PM   #26
OwlDance
Drives: Halo 86, '19
If I recall correctly the MAP oil cooler you're using is fairly small and is just enough for most NA cars on track, roughly. With a turbo I'm not surprised the temps are reaching as high as they are, coolant combined, especially if idling. You probably just need a bigger oil cooler. Likewise, heavier oils heatsoak faster and flow less and exchange heat out less efficiently. The temperature changes in your original post seem to correspond with the relative weather where you're located at as well, especially when idling and there's no airflow to exchange heat.
Consider a heavier duty oil cooler and possibly a thinner oil in conjunction, and hooded vents to keep bay temps down. Seems pretty straightforward to me, though there's not much one can do about idle heatsoak. Vented hoods should help with that though.
OwlDance is offline   Reply With Quote
Old 07-07-2019, 10:24 PM   #27
thinkV
Drives: BRZ Turbo
Hmm okay, perhaps I need to change the core. Can you recommend one that I can just replace with already installed AN fittings?
This is the kit at the moment (13 row): https://www.maperformance.com/produc...frs-subaru-brz
I actually do have verus hood vents, and my engine bay temp seems very cool now with the coated pipes, I can touch them.
Old 07-07-2019, 10:40 PM   #28
ZZT86
ZZT86's Avatar
Drives: BR86
@thinkV 1-2C temp drop can't be right, I can touch my header after a drive it's that cool. Prosport gauges aren't all that flash either from memory.
HVT non rising Camber Plates dstrout Brakes, Suspension, Chassis 7 05-23-2019 10:09 PM
HVT non rising Camber Plates norcalpb Brakes, Suspension, Chassis 12 07-24-2018 08:08 PM
HVT Non-Rising Camber Plates Keenercarguy Brakes, Suspension, Chassis 7 05-08-2017 04:04 PM
Oil temperature rising? ChiTownFrs Issues | Warranty | Recalls / TSB 19 08-04-2015 07:59 AM
RPMs rising while at a stand still kpamir Engine, Exhaust, Transmission 13 10-29-2014 06:45 PM
