Old 05-19-2019, 09:48 AM   #1
JDMPR725
Drives: 2013 Scion FRS (10-Series)
Any good stereo systems for an 86?
I'm buying an 86 in several months but I'm going over my to-buy parts list and looking for an aftermarket stereo system to replace the OEM center console radio. I'd like to know any good alternatives you guys recommend or use in your cars.
I'm personally looking for a stereo system with a removable head to prevent thieves from stealing it (not a lot that comes with that feature, unfortunately). An Android OS with good CPU/RAM, maybe a micro sd feature, and with a rear-camera monitor feature.
JDMPR725 is offline   Reply With Quote
Old 05-19-2019, 11:49 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'm adding a turbo since the stock sound system didn't have what I was looking for. UEL headers with a muffler delete is a good choice for pretty cheap. A couple companies make ITBs for this engine if you're a huge sound enthusiast. There are a lot of options
maslin (06-19-2019)
Old 05-19-2019, 03:02 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
he did post in the correct section...
so 1/2 the responses you'll get are that audio in this car is an absolute waste of money. the other half will respond with their specific brand preferences as the greatest thing, and pricing will be all over the board. my post isn't going to be any different .
first, you need to come up with a rough cost where you want to be.
some of the guy's running android units are starting to hit the limitations-- they're all cheap crap, many won't run more than 1 app at a time. i don't believe any of them have removable screens. windows-based carpc's are a better option, but integration fell flat 10 years ago, and now nearly doesn't exist.
personally, i run a pioneer deh-80prs. it does everything i need for audio, looks cheap so no one touches it, but also has a removable faceplate and sd card slot if one were so inclined. it doesn't look the prettiest in the dash, and there's no big screen, but i'm happier that way..
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
wheelhaus (06-19-2019), why? (05-21-2019)
Old 05-19-2019, 03:24 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
Try the one used in the BRZ MY2012-15...
Old 05-19-2019, 03:47 PM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Look, the BIGGEST problem with the stock radio in the 86 is connectivity.
Think of it like a 1 din radio from 10 years ago, it just happens to have a big screen for a backup cam. It's THAT useless, AM/FM/BT/AUX don't count on anything more than that. Aha? HAHA! wonky unreliable connectivity, useless, and don't you start hoping we'll get a carplay/android auto update like lexus selling carplay software updates, this radio is just in the iM, 86 and C-HR, we're trash peasants. However, prior to purchase based on comments from the internet, I had assumed I'd have to chuck it in the trash on week 1 because "hurrrr! sound bad!".
Truth is, the sound quality is fine for a stock system, that's it, "fine". you don't have to assume it's unusable trash, and if you just want [sound] it's tolerable.
I'm still gonna chuck mine in the trash eventually, but it was tolerable enough that it's priority has fallen behind wheels/tires/wing/underbody aero.
Old 05-19-2019, 10:00 PM   #6
JDMPR725
I suppose you're right. There isn't much of what I would ideally find on what I'm looking for. The one you have does look nice and I have a similar pioneer model in my Integra but want to have that removable head feature most of all.
Old 05-20-2019, 03:16 AM   #7
soundman98
soundman98's Avatar
I had a pioneer appradio with 7" flip up screen for a while--$350 i believe, similar to the 80prs. Not a high end unit by any means, just had a fancy 7" touchscreen
It remains the one radio someone broke into my car for. So i actively avoid radio's with screens now. But then i also had a carpc for a while with a built-in 7" screen(custom built transflective layers, was around $700), and i never had problems the entire time that was installed...
Old 05-20-2019, 04:52 AM   #8
Alastor
Alastor's Avatar
Drives: Toyota gt86 my19
Hi
If you havent a problem with your money, you have a Pioneer avh-z9100dab. Is antifet.
Alastor is offline   Reply With Quote
Old 05-21-2019, 08:49 AM   #9
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I have a Pioneer DEH-P01 from japan I'm tempted to install because the sound quality of the stock system really is that bad, and the navigation is even more useless. I mean the stock system is fine for listening to podcasts, but that's about it.
However you should really go to https://www.diymobileaudio.com/forum/, as they are the kings of car audio and I am sure there are plenty of reasonably priced options that have what you are looking for that they will know about.
why? is offline   Reply With Quote
Old 06-19-2019, 05:29 AM   #10
luisark
Drives: Toyota Corolla 2017
you can take a look at this car stereo http://www.carstereoarkright.com removable and RAM available in 2G or 4G
luisark is offline   Reply With Quote
Old 06-19-2019, 01:23 PM   #11
wheelhaus
wheelhaus's Avatar
Originally Posted by soundman98
personally, i run a pioneer deh-80prs. it does everything i need for audio...
Same! Fantastic little unit, all function and virtually no flash.
If you’re just looking for a better head unit, find one that looks pretty and does what you want. If you’re looking for a whole system upgrade, thats a different story, you’ll need to pick more carefully.
The DEH-80PRS is marketed as a high sound quality head unit, and will give you tuning features to really dial in great sound, but you need more/better gear to make it sing. It doesn’t have all the flash and eye candy and additional navi/app features but it does have powerful audio processing and decent DACs. If you have no intention to go such a route as this then the first line of this paragraph is all you need.
Personally mine is wired as an “active front stage” where the 4 primary channels are dedicated to component mid woofers and tweeters up front, and two small 8” subs in small custom enclosures in the corners of the trunk. My rear drivers in the back seat are disconnected. Everything is sound deadened, EQ’d, and time aligned to sound like the music is right in front of the driver’s seat. This setup is all driven by an Alpine PDX9. I can go into more detail if you like, but you need to set goals first, then we can help you pick parts and figure out how to execute it.
The Following User Says Thank You to wheelhaus For This Useful Post:
soundman98 (06-20-2019)
Old 06-20-2019, 01:59 AM   #12
soundman98
soundman98's Avatar
Coming from a carpc, I'm still missing independent channel eq's and more variety of crossover selection(dayton point sources for high end, so still full active, but with a low tweeter xover), so I'm considering adding a dayton or minidsp unit for the lacking functionality.
How did you set up the time alignment? I've tried it a few times and always just end up with headaches from the psychoacoustics being screwy...
Old 06-20-2019, 11:03 PM   #13
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I currently have an Android unit from China which has treated me well for the past few years but have had my eyes on the below unit which sports wireless Android Auto.
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
B-R-Z is offline   Reply With Quote
Old 04-02-2021, 11:17 AM   #14
blackstripe77
I’ve been looking into the DEH-80PRS - everything about it seems great, but have some concerns that the unit is a little outdated. Is the head unit able to display text when an iPhone is connected via Bluetooth, and will Spotify also play via Bluetooth?
blackstripe77 is offline   Reply With Quote
aftermarket, android, audio system, music, toyota 86
2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo brzsubarusti13 Audio/Visual, Electronics, Infotainment, NAV 11 02-27-2016 07:33 AM
Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo dssence Electronics | Audio | NAV | Infotainment 0 01-27-2015 07:43 PM
Pulley systems, what are they good for and worth the money? K-NoMs Engine, Exhaust, Transmission 44 09-06-2014 03:01 AM
Any good stereo installers in NY area that have worked on the frs? mikeg7827 NY / NJ / CT / PA 18 09-09-2013 11:07 PM
Good Reputable Reasonably priced stereo installer on Long Island? mikeg7827 NY / NJ / CT / PA 1 11-25-2012 04:52 PM
