#15 |
The other good time to double clutch is for a missed upshift. Consider what happens when you wait too long upshifting between gears. The input side slows down too much. Now the syncros are doing work to bring the input side back up to speed.
It's easy to miss 1-2 first thing in the morning when the transmission fluid is cold and thick. It's also easiest to practice timing in the morning. Start out in first. Push in the clutch and pause for a sec before disengaging first. Notice how you have to tug? You're working against all the gears squeezing & shearing that thick shit. If you time it right and begin tugging just as you've disengaged the clutch, it slips out of gear with a tiny flick. If you do that flick and immediately put a tiny bit of steady pressure on the slip ring, it'll flop right into second every time. But if you miss, let go. Double clutch to spin up the input side again like you're rev matching for first, and try again. I've had some really cold mornings when third time is a charm. At no point do I ever have to lean on the gearshift.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | jc7993 (05-19-2019) |
#16 | |
Drives: Looking to buy
Makes sense when you put it that way. Most of the time I try shifting quickly right after I press in the clutch and I get the crunching shift. I feel like if I hold out on shifting to the next gear will make the rpm too low and would have to add gas. I usually shift at 2-3000 rpm range. Sent from my iPhone using Tapatalk |
#17 | |
Is it safe to say that at 3500rpm from 4th to 5th and 5th to 6th, would be the same? Sent from my iPhone using Tapatalk |
#18 | |
![]() I do know that 1 thru 4 shifting clutchless, the rpms need to be kicked up the higher you go up the gears. humfrz |
#19 |
That's perfect for a cold engine but you have to be REALLY quick at that low speed because the ratios are so close and the gear oil is especially thick in the first few minutes of driving on a cold morning.
Have you ever seen a chart like this? I ask because it's good at showing how the difference in engine speed between gears increases as engine speed at the time of the shift also increases. It also explains why syncro life is preserved by pausing in neutral a little longer for redline shifts.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | jc7993 (05-20-2019) |
#20 |
Shifting in this car is an acquired skill. I’ve driven manual transmissions exclusively since 1985, VW products. And my BRZ is quirkier. And lots of fun when you get the hang of it.
But I still stall it out once in a while. Just last week at a traffic light. Not enough juice and not fluid enough left pedal. I do like the way the shifter goes through the gates. Brute force doesn’t go well, especially 2nd to 3rd. I find a light touch on the shifter gives great results. As does shift points north of 5500 RPM. Shoes impact driveability as well. Boots aren’t appropriate attire in the drivers seat. My faves are Teva watershoes. Mesh uppers with grippy soles. Lightweight and narrow. |
#21 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
if OP cannot tell he made a bad shift which IMO is pretty obvious with this gearbox then he needs a good teacher in person, I doubt we are going to help over the interwebz...the manual gearbox is finicky when cold & changing trans oil is a waste of time and money..
#22 | |
I know that my shifts aren’t good yet but it’s decent enough that I’m not damaging the car constantly by doing things I’m not suppose to. Also, yes you are correct that I probably need a good teacher to show me what I’m doing wrong and what is the norm for the BRZ since I’ve only been driving this car for 2 months now. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to jc7993 For This Useful Post: | HKz (05-20-2019) |
| Reverse lock out button on IRP short shifter is stuck due to my dumb self | Mdulin | Engine, Exhaust, Transmission | 4 | 01-28-2019 05:44 PM |
| Shifter Stuck | Strife26 | Engine, Exhaust, Transmission | 5 | 08-02-2017 09:18 AM |
| Shift lock stuck after short | Anomie | Issues | Warranty | Recalls / TSB | 7 | 01-24-2017 01:44 PM |
| Shift Gate | simonweisberg | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 07-02-2015 05:17 PM |
| Shift resistance going into gate (notchiness) | 1Cor10:23 | Engine, Exhaust, Transmission | 14 | 12-06-2013 07:16 PM |
