Old 05-18-2019, 12:57 PM   #29
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
The last time I was up around those speeds I was cruising completely undramatically with two fingers on the wheel.
First thing to check is shocks and alignment.
Old 05-18-2019, 03:44 PM   #30
now, THAT is for teaching the newbies bad habits!
Old 05-18-2019, 11:56 PM   #31
gravitylover
I brought the fronts down 1psi and it seems to have helped but I only got to the mid 80's. I'm going to need another opportunity with someone hauling ass so I can follow a bit behind and run them up to 95 or so to see if that does it.
Old 05-19-2019, 01:53 AM   #32
I wouldn't mess around at that speed. If you aren't obviously rock solid then something is still wrong. Best wishes for a good conclusive fix.
strat61caster (05-19-2019)
Old 05-19-2019, 05:26 PM   #33
gravitylover
There's only one way to find out Suspension bits appear to be alright but the car is almost 7 years old so I bet the bushings are worn and that's really what the problem is. I'll get to them at some point this summer when I have better cash flow, that heart attack and 3 months of lost income put a hurt on us.
Old 05-19-2019, 05:33 PM   #34
Oh, shit! I forgot about that! How the hell have you been?
As sensitive to changes in tire pressure this car is, I can only imagine what worn suspension bits do to the handling. Keeps the sphincter in shape, at least.
gravitylover (05-20-2019)
Old 05-20-2019, 03:43 PM   #35
gravitylover
Doing well, thanks. I think it has been a slow recovery but I'm not terribly patient when it comes to being under the weather or injured. I still think I'm 25 and recover in a matter of days
Previously I had the Conti EC DWS and had to run them much higher (36/37ft and 34rr) just to get them to be stiff enough not to roll over in corners, these need to be lower (34/35ft) for stability at speed.
The Following 2 Users Say Thank You to gravitylover For This Useful Post:
strat61caster (05-20-2019), Ultramaroon (05-20-2019)
Front-Pipe Question for FRS FewTooManyBeers Engine, Exhaust, Transmission 12 02-15-2019 10:22 PM
Front LCA question caffeinejunky Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 04-30-2014 08:54 PM
Question for for someone who has had the front bumper off 10Tim Cosmetic Modification (Interior/Exterior/Lighting) 5 09-30-2013 05:34 PM
Front lip question... brz_guy Cosmetic Modification (Interior/Exterior/Lighting) 13 05-17-2013 01:51 PM
Frs/brz front piece question lavisxice Scion FR-S / Toyota 86 GT86 General Forum 22 01-10-2013 06:42 PM
