Old 05-17-2019, 09:13 AM   #1
tomm.brz
Drives: brz 2017 hksv2
Lean AFR during cold start
Curious about what you guys get as AFR during start with cold engine
tuned many cars remotely and locally and always see around 15.44 target afr during cold start.. then slowly going to stoich as it warms up
Still haven't figured out how to hijack this leaning as it seems to me hard coded into ecu and/or not defined in ecutek tunes
Why do these cars lean out during start? I thought OEMs usually made the cold start rich to provide a more stable idle
Old 05-17-2019, 09:52 AM   #2
steve99
Drives: FT86
O2 sensors dont work accuratly till they are warmed up to a few hundred degrees
Check fuel system status is not 1 warmup mode.
Old 05-17-2019, 10:05 AM   #3
tomm.brz
it persist a bit also after the fuel system status 1
it starts 15.44 then 14.99, then 14.90 then 14.7 after a while
also I have a aem wideband that pre heat itself, and actually even when cold, the stock lambda seems pretty good when not warmed up totally
Also even if fuel system status is "1".. why do this car target a leaner afr during this status and during cold start, when logically should be rich?
Anyway looking at Catalyst#1 temp, i think the sensor go in temperature pretty soon since i reach 600 celsius in less than 30 seconds, after 5 seconds is already at 200 celsius
Old 05-17-2019, 10:25 AM   #4
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I guess you mean 100 celsis in the first 30 seconds. I was thinking maybe they do this to warm up the catalyst sooner?
Old 05-17-2019, 10:54 AM   #5
tomm.brz
In the cold start, even with lower idle and less retard than a stock tune, it heats up so much quicker than you think.. try log catalyst#1 temp
Old 05-17-2019, 12:26 PM   #6
steve99
Drives: FT86
Yeah its not going to provide accurate reading till its arround 600 plus celcius
And theirs a lot of offsets applied during cold start phase. Probably many not known or not defined in tables
Old 05-17-2019, 01:00 PM   #7
tomm.brz
i do see the fuel quantity total going down while it warms up, but the wideband says it's lean.. is it really for cat warming up faster?
Old 05-17-2019, 01:29 PM   #8
steve99
Drives: FT86
Believe so, retarded timing and lean afr will create heat.
Cold start pop Ash3482 Engine, Exhaust, Transmission 3 03-07-2019 07:39 PM
Cold Start Help Kayysonie Software Tuning 39 03-31-2016 11:35 PM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 02:55 AM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
