Old 05-16-2019, 12:03 PM   #15
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by smg1138 View Post
Not trying to get too off topic, but did have sort of a related question. Would it be worth running 5w30 for autocross and light track duty in summer? Around here ambient temps can get well into the upper 90's during the summer and have wondered if I should switch to something thicker than 0w20?
IMO there's no reason not to run 5w30 if you're going to be tracking it.
smg1138 (05-16-2019)
Old 05-16-2019, 12:14 PM   #16
dpaqu
Drives: 2018 Gt86
Originally Posted by 86_IT View Post
Go Jackso Racing. Perrin kit is easy to outgrow as you get faster and begin to turn multiple hotlaps.
From reading your posts it looks like you have a lot of track time. Any thoughts on the oil to water setups?
dpaqu is offline   Reply With Quote
Old 05-16-2019, 12:19 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by dpaqu View Post
What oil cooler are you running?
Setrab 613
NoHaveMSG is online now   Reply With Quote
Old 05-16-2019, 02:15 PM   #18
RSCrawford
Drives: 2018 Brz
data
Originally Posted by ZDan View Post
Regarding oil pressure with vs. without an oil cooler:
https://www.ft86club.com/forums/showthread.php?t=91820
From this data it looks like with 5w30 and no oil cooler, oil temps get up to ~275F and pressure is ~7.5 psi/1000rpm.
WITH an oil cooler and 5w30 oil, temps are down around 250F, but pressure is still ~7.5psi/1000rpm.
Theory: increase in pressure from cooler oil is exactly negated by the pressure drop from the cooler itself, maybe?
Anyway, I haven't seen any evidence that I *need* an oil cooler for my track usage, so for me, IMO it's not worth the cost/effort/risk of having one installed.
A forum post backed up with hard data, you sir are outstanding.
Good info.
RSCrawford is offline   Reply With Quote
Old 05-16-2019, 02:40 PM   #19
FirstWinter
Drives: Car
Jackson Racing or Greddy.
FirstWinter is offline   Reply With Quote
Old 05-16-2019, 02:42 PM   #20
new2subaru
Weight Weenie
Drives: 15 FR-S
@falcon_wizard
More data.
https://www.ft86club.com/forums/show...&postcount=328
I don't know why you wouldn't run a cooler for track. I installed mine this pat winter.
Old 05-16-2019, 03:39 PM   #21
Icecreamtruk
Drives: Track preped NA FRS
Originally Posted by new2subaru View Post
@falcon_wizard
More data.
Because apparently a couple of hundreds and an hour or two to install a sandwich plate and a couple of lines is too much work and risks involved and people would rather throw a new engine in for a couple thousands every couple of years. Why else would it be, right?
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
strat61caster (05-16-2019)
Old 05-16-2019, 05:34 PM   #22
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If I blow up my engine maybe I don't have to go in for the valve spring recall...
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Icecreamtruk (05-16-2019), NoHaveMSG (05-16-2019)
Old 05-16-2019, 06:08 PM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
Looking at 2nd plot, if my oil temp steadily climbed to 280F during a track session without stabilizing, I would definitely consider an oil cooler. My oil temp consistently goes up to just over 270F and then holds, every event, every session. In my case the oil temperature is under control and not trying to "run away", and in my judgement 275F is not unreasonable for 5w30 synthetic in this car for my usage (~12 track days per year, ~4 15-min. sessions per day).
I don't think not running an oil cooler for limited track usage equates to needing a new engine every couple of years...
I don't think an oil cooler is a bad idea for casual track usage, I just don't think it's necessarily a requirement.
The Following 2 Users Say Thank You to ZDan For This Useful Post:
new2subaru (05-16-2019), strat61caster (05-16-2019)
Old 05-16-2019, 08:16 PM   #24
ayau
Drives: Some rust bucket
Casual track days? Probably not worth the risk considering it's another point of failure.
Also if your engine fails with an oil cooler, Subaru won't warranty it. Maybe you're able to carefully remove the oil cooler, so it looks like it was never there in the first place.
If your engine is STOCK and doesn't have an oil cooler, you have a better chance of Subaru covering it under warranty.
The Following User Says Thank You to ayau For This Useful Post:
ZDan (05-16-2019)
Old 05-16-2019, 08:56 PM   #25
new2subaru
Weight Weenie
Drives: 15 FR-S
I could get 7 laps in on a short track and my oil would start climbing past 250F. That was enough for me to pit and cool down. I was toast anyways but that's besides the point lol
I would not want my oil at 275F but to each his own.
Old 05-16-2019, 09:29 PM   #26
ZDan
ZDan's Avatar
Drives: '23 BRZ
From another oil cooler thread in which I go on a bit...
http://www.ft86club.com/forums/showt...+cooler&page=2
FWIW here's how Ford characterizes oil temperatures in '18 Mustang Factory Service Manual:
38-60° C (100-140° F) (low)
61-137° C (142-279° F) (normal)
138-146° C (279-295° F) (warm)
147-160° C (297-320° F) (hot)
Old 05-16-2019, 09:53 PM   #27
new2subaru
Weight Weenie
Drives: 15 FR-S
I'll keep that in mind if I ever buy a Mustang
JK, like I said to each his own. I'd rather have my oil temps on the lower side.
The Following User Says Thank You to new2subaru For This Useful Post:
Joesurf79 (05-16-2019)
Old 05-16-2019, 10:07 PM   #28
nico_rsx
Drives: BRZ 2017 Pure Red, MT
People who do autocross in street class (like me), can't install an oil cooler because of the rules. It's a stupid rule, but it is what it is.
nico_rsx is offline   Reply With Quote
The Following User Says Thank You to nico_rsx For This Useful Post:
Icecreamtruk (05-17-2019)
TRD and jackson racing oil cooler V1 FR-Sky Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 05-10-2019 02:45 AM
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 11:16 PM
WTB: Jackson Racing Oil Cooler wrb.brz Want-To-Buy Requests 0 03-12-2017 02:31 PM
FS: Jackson Racing Oil Cooler Cop Engine, Exhaust, Bolt-Ons 8 06-27-2016 02:39 AM
