Old 05-15-2019, 07:47 AM   #1
Vital
Drives: 2015 BRZ
Subaru 80w-90 Diff oil
I was at the dealership recently and saw that they have 80w-90 diff oil. I was just curious does this work for our cars? I know the manual says to use a GL-3 and higher or 75w-90 oil. Heres a link for reference.
https://parts.subaru.com/p/Subaru__/...A427V1800.html
Old 05-15-2019, 05:47 PM   #2
KingJon1991
Drives: scion frs 2015
i use 80w-90 works fine in my car got tired of buying the small quarts
KingJon1991 is offline   Reply With Quote
The Following User Says Thank You to KingJon1991 For This Useful Post:
Vital (05-16-2019)
Old 05-16-2019, 09:39 AM   #3
Vital
Drives: 2015 BRZ
Ok cool, yea i saw that and couldnt find any information on the forums about this oil. Maybe ill try it once i need to change my diff fluid
Old 05-16-2019, 03:41 PM   #4
tobin
tobin's Avatar
Drives: '13 BRZ
I just used this in my diff. Changed my trans fluid at the same time with 75w90.
tobin is offline   Reply With Quote
The Following User Says Thank You to tobin For This Useful Post:
Vital (05-17-2019)
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits? mistople Engine, Exhaust, Transmission 10 09-21-2018 06:01 PM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
OEM Diff Kregar Mid-Atlantic 1 07-12-2016 04:30 PM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
