Old 11-01-2018, 03:15 AM   #827
CSG Mike
CSG Mike's Avatar
Originally Posted by Iceman View Post
Here you go:
I guess it needs a more refined tune to see the best result.
198 (stock, as evidenced by the torque curve) -> 209 horsepower is a very, very poor gain. Here is the dyno for the DT tune provided by CSG with the Ace header package.
5.556% gain with the dyno you posted, versus 17.86% gain with a good tune. That's over 3x the gains when tuned properly.
Iceman (11-02-2018)
Old 11-01-2018, 03:24 AM   #828
CSG Mike
CSG Mike's Avatar
Here's a very rough photoshop overlay of the two dynos. Thick lines are the DT/CSG Ace dynos, the thin lines are the provided dynos.
Lantanafrs2 (05-15-2019)
Old 11-01-2018, 03:31 AM   #829
CSG Mike
CSG Mike's Avatar
Another graph, with the graphs scaled identically but translated to best-fit stock torque curves, so that torque gains against stock can be compared.
Old 05-15-2019, 01:08 AM   #830
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We have released new NA Stage 1,2 and ACE tunes for the BRZ/86/FRS. (Including Flex Fuel Updates)
Version 12.00 for Stage 1
Version 13.00 for Stage 2
Version 14.00 for Stage 2 + ACE header.
Improvements include
- New Cam Table Profiles
- New Fuel Table Adjustments,
- New Timing Advance Tables
- New DI/PI control mechanism
We also have added on the EcuTeK ECUConnect
- Custom MAF Trim %
- Custom WOT Timing %
- Custom Traction Control % (NA Tunes)
- Custom Boost Pressure Set Point (Flash & Go Tunes)
- Optional Pops % Bangs Switch
- Optional Crackle Slider
RaceROM Maps Have Also Changes
- Custom Race Throttle Spec (tested for immediate response)
- Improved Autoblip (for those that like that option)
- New Valet features
Regards,
William Knose
The Following 6 Users Say Thank You to DeliciousTuning For This Useful Post:
C4RBON (05-15-2019), Code Monkey (05-15-2019), CSG Mike (05-16-2019), Iceman (05-20-2019), Reamer (05-15-2019), TorqueMan777 (05-18-2019)
Old 05-15-2019, 02:01 AM   #831
conehead
Drives: RS 2.0
Wow, glad I found this thread. This car was begging for a 4-2-1 header. UEL was a half assed bandaid for the torque dip.
conehead is offline   Reply With Quote
Old 05-15-2019, 06:27 AM   #832
evoto86
Drives: manual Toyota 86
You went from UEL to EL ?
evoto86 is offline   Reply With Quote
Old 05-15-2019, 02:13 PM   #833
FastWhite
Drives: Subaru BRZ Limited M/T
So, what is the difference then from an older DT/Ace tune to this newer revised version.
I’m anal enough to get the update if the gains are enough?
FastWhite is offline   Reply With Quote
Old 05-15-2019, 05:39 PM   #834
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
so if my ace + flex tune is v11.x i guess i am very behind?
Old 05-15-2019, 08:42 PM   #835
conehead
Drives: RS 2.0
No, I will go from stock to 4-2-1. UEL has that nice subie sound, but it is not the best option for performance. Actually wondering now the different versions of this exhaust compare (150/350/400/etc).
I'm new to this platform so maybe a 4-2-1 option is old news, but I didn't know about it. My SVT Focus came stock with a 4-2-1 and it was perfect. There were no aftermarket headers that could beat it.
Old 05-15-2019, 09:05 PM   #836
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
First post in this thread is from 4 years ago
ineedyourdiddly
Old 05-15-2019, 10:19 PM   #837
jflogerzi
jflogerzi's Avatar
Probably not. The lower numbers produce more in the top end for track and the higher end numbers bump more in the mid range and also give you some top end where it's better suited for DD driving.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 02-17-2020, 07:16 PM   #838
Pat
Pat's Avatar
Drives: 2023 BRZ
Does anyone have a dyno comparing the original Delicious stage two tune to the revised one? I'd love to see how they compare on a graph, even though I understand some of the benefits may not show up in that format.
The Following 2 Users Say Thank You to Pat For This Useful Post:
gpvecchi (02-18-2020), SuperTom (02-17-2020)
Old 02-19-2020, 01:28 AM   #839
jflogerzi
jflogerzi's Avatar
Get in touch with CSG. CSG now does in house tuning vs working with DT now. The update should be free for you if your already tuned with DT.
The Following User Says Thank You to jflogerzi For This Useful Post:
SuperTom (02-19-2020)
Old 02-19-2020, 11:50 AM   #840
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks, jflogerzi. Mike and I are already planning on talking Friday.
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 07:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 10:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 09:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 01:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 07:22 PM
