Old 11-01-2018, 02:31 AM   #827
CSG Mike
CSG Mike's Avatar
Another graph, with the graphs scaled identically but translated to best-fit stock torque curves, so that torque gains against stock can be compared.
Old 05-15-2019, 12:08 AM   #828
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We have released new NA Stage 1,2 and ACE tunes for the BRZ/86/FRS. (Including Flex Fuel Updates)
Version 12.00 for Stage 1
Version 13.00 for Stage 2
Version 14.00 for Stage 2 + ACE header.
Improvements include
- New Cam Table Profiles
- New Fuel Table Adjustments,
- New Timing Advance Tables
- New DI/PI control mechanism
We also have added on the EcuTeK ECUConnect
- Custom MAF Trim %
- Custom WOT Timing %
- Custom Traction Control % (NA Tunes)
- Custom Boost Pressure Set Point (Flash & Go Tunes)
- Optional Pops % Bangs Switch
- Optional Crackle Slider
RaceROM Maps Have Also Changes
- Custom Race Throttle Spec (tested for immediate response)
- Improved Autoblip (for those that like that option)
- New Valet features
Regards,
William Knose
Old 05-15-2019, 01:01 AM   #829
conehead
Drives: RS 2.0
Wow, glad I found this thread. This car was begging for a 4-2-1 header. UEL was a half assed bandaid for the torque dip.
conehead is offline   Reply With Quote
Old 05-15-2019, 05:27 AM   #830
evoto86
Drives: manual Toyota 86
You went from UEL to EL ?
evoto86 is offline   Reply With Quote
Old 05-15-2019, 01:13 PM   #831
FastWhite
Drives: Subaru BRZ Limited M/T
So, what is the difference then from an older DT/Ace tune to this newer revised version.
I’m anal enough to get the update if the gains are enough?
FastWhite is offline   Reply With Quote
Old 05-15-2019, 04:39 PM   #832
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
so if my ace + flex tune is v11.x i guess i am very behind?
Old 05-15-2019, 07:42 PM   #833
conehead
Drives: RS 2.0
No, I will go from stock to 4-2-1. UEL has that nice subie sound, but it is not the best option for performance. Actually wondering now the different versions of this exhaust compare (150/350/400/etc).
I'm new to this platform so maybe a 4-2-1 option is old news, but I didn't know about it. My SVT Focus came stock with a 4-2-1 and it was perfect. There were no aftermarket headers that could beat it.
Old 05-15-2019, 08:05 PM   #834
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
First post in this thread is from 4 years ago
ineedyourdiddly
Old 05-15-2019, 09:19 PM   #835
jflogerzi
jflogerzi's Avatar
Probably not. The lower numbers produce more in the top end for track and the higher end numbers bump more in the mid range and also give you some top end where it's better suited for DD driving.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 02-17-2020, 06:16 PM   #836
Pat
Pat's Avatar
Drives: 2023 BRZ
Does anyone have a dyno comparing the original Delicious stage two tune to the revised one? I'd love to see how they compare on a graph, even though I understand some of the benefits may not show up in that format.
Old 02-19-2020, 12:28 AM   #837
jflogerzi
jflogerzi's Avatar
Get in touch with CSG. CSG now does in house tuning vs working with DT now. The update should be free for you if your already tuned with DT.
Old 02-19-2020, 10:50 AM   #838
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks, jflogerzi. Mike and I are already planning on talking Friday.
Old 08-24-2020, 09:39 AM   #839
prezes_wojtek
Drives: GT86 track usage
To anyone who is using this header: What is header height vs stock header? Is it shorter or taller then stock header? Does it fit OEM bottom engine cover with some space to spare or it's tight fit and any bump to engine cover will impact header too?
Bottom clearance is big topic for me due to quality of roads nearby.
prezes_wojtek is offline   Reply With Quote
Old 08-24-2020, 09:46 AM   #840
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
It seems to vary by person. Many have no issues with the header clearing the engine cover, while for some, it touches. It has become well known that it is recommended to hammer out a couple spots on the cover for the header to have no clearance issues. I did this to be sure before the header install, and never had any problems to begin with.
https://www.ft86club.com/forums/show....php?p=3042220
https://www.ft86club.com/forums/showthread.php?t=96358
Dzmitry is offline   Reply With Quote
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
