Old 05-06-2019, 10:08 PM   #1
j_ros94
Drives: 2017 Subaru BRZ
Greddy T518Z Whp
Im making 338whp with greddy t518z with dw 700cc fuel injectors 65c fuel pump
Skuns 2 oil cooler
Radium engineering dual catch can
Competitive stage 3 clutch with forge flywheel and omni 3 bar map. Is this ok?
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
The Following User Says Thank You to j_ros94 For This Useful Post:
JBezugs (05-16-2019)
Old 05-06-2019, 11:33 PM   #2
jflogerzi
jflogerzi's Avatar
Not sure what your asking? With knowing fuel type, tuner and PSI... We don't read minds
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 05-06-2019, 11:44 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This is like holding a lit match under paper. It's only fine until it's not fine. There's no way of knowing if it's too close to the paper until it ignites.
DaBoBo21 (05-07-2019)
Old 05-07-2019, 02:06 AM   #4
j_ros94
94 pump tuned by sasha from onpoint dyno and he said peak boost was 13 psi
Old 05-07-2019, 02:21 AM   #5
WC-BRZ
Drives: Black BRZ
How many miles have you had on this kit so far with the 338whp tune?
Is this a daily driven car? Any autocross or track days?
Are you on the stock motor mounts? Stock Subframe and diff bushings as well?
Is it true that this setup actually spools surprisingly quick for what it is? Do you find it kind of falls on its face at redline or does it feel strong all the way?
Any regrets on your build so far?
Excuse all the abrupt questions but I currently have the biggest hard on for this kit - to me it seems like the best bang for buck. Thanks for posting this up
WC-BRZ is offline   Reply With Quote
Old 05-07-2019, 05:52 AM   #6
j_ros94
I just got the kit recently installed less than a week ago. Engine motor and diff bushings are fully stock. It does spool quickly. No regrets just a little concerned how it got to 13psi peak boost.
Old 05-07-2019, 08:02 AM   #7
tomm.brz
Drives: brz 2017 hksv2
looks good
your radium catch can crank side (on the right, in your picture) seems routed wrong
tube tube that comes from the crank should go in the upper hole of the catch can, according to the radium instructions
j_ros94 (05-26-2019)
Old 05-07-2019, 03:36 PM   #8
j_ros94
Originally Posted by tomm.brz View Post
looks good
Thanks for the heads up. Im gonna see if they can fix it for me.
Old 05-10-2019, 12:05 PM   #9
CSG Mike
CSG Mike's Avatar
That's some solid power!
Do you have a picture of the full curve?
j_ros94 (05-10-2019), wparsons (05-10-2019)
Old 05-10-2019, 12:08 PM   #10
j_ros94
I dont, unfortunately. I wanted to take a pic of the peak boost cuz it made 13psi
Old 05-10-2019, 12:08 PM   #11
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Have them pull out that useless sound tube too.
Old 05-10-2019, 12:08 PM   #12
jflogerzi
jflogerzi's Avatar
Second. For pump those are good numbers. Not sure I would run 13psi on pump but you do have 94.. do you have e85 around you?
Old 05-10-2019, 12:10 PM   #13
j_ros94
What sound tube?
Old 05-10-2019, 12:11 PM   #14
j_ros94
I have 94 no e85. Im gonna see if we can adjust the actuator arm cuz 13 psi is nice and all but reliability > power lol
jflogerzi (05-10-2019)
GReddy T518Z Turbo Kit Richytort Engine, Exhaust, Bolt-Ons 4 09-01-2017 01:39 AM
FS: GReddy T518Z Turbo Jefffrs Engine, Exhaust, Bolt-Ons 2 08-15-2014 12:08 PM
BRZ GReddy t518z NOTORIOUS.BRZ BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-15-2014 02:15 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 06:09 PM
