Old 05-04-2019, 11:13 AM   #8345
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
Originally Posted by SpeedWi View Post
I zipped ties the wiring harness to the strut brace. Kept it off the engine and prevented it from moving around
Sent from my SM-G960U using Tapatalk
After that it didn't happen anymore. Was gonna buy a new harness, but never did because it stopped happening.
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
The Following User Says Thank You to SpeedWi For This Useful Post:
jflogerzi (05-05-2019)
Old 05-05-2019, 12:12 AM   #8346
jflogerzi
jflogerzi's Avatar
Check the idle pulley. The one you install. May be squeaking and need some lube.
I had another belt that was included and this one looked way better. Swapped belts and squeak gone
2013 Series 10 FRS #553
Old 05-05-2019, 12:32 AM   #8347
SpeedWi
SpeedWi's Avatar
Old 05-08-2019, 02:04 AM   #8348
jflogerzi
jflogerzi's Avatar
Getting more whine with the stock intake. I saw this video on YouTube where this guy added a sound tube from the intake through the firewall to amplify the whine. Car was a mustang but still same concept. Gotta admit I was looking forward to a louder wine. What are ppl thoughts on this and using the old firewall opening where the OEM sound tube was?
Sent from my ONEPLUS A5010 using Tapatalk
Old 05-08-2019, 08:19 AM   #8349
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
You may be the guinea pig when doing this with the stock intake. If you're willing to try an alternative approach, the Moto East 3" short intake really makes the SC scream -- literally. You could hear it from a half mile away probably. Not comparable to stock at all (whine is audible even from ~1500rpm)
ajcarson11 is offline   Reply With Quote
Old 05-08-2019, 12:47 PM   #8350
jflogerzi
jflogerzi's Avatar
If I can find a second Intake pipe for cheap I will test this. Even with the shorty 3inch I would need a new metal intake pipe going to the charger or does it support the stock plastic one?
Old 05-08-2019, 02:30 PM   #8351
86TOYO2k17
Drives: 2017 toyota 86
If you really want to get the whine, the nameless metal intake pipe with either the aforementioned 3” filter, or a Perrin big maf 3” cai if you can find one.
3” filter does Supports the plastic pipe as well though. But the metal pipe adds a lot of whine. More prone to heat soak though.
Old 05-08-2019, 02:37 PM   #8352
ajcarson11
I don't have experience with the combination of the 3" Moto-East short-ram intake and metal intake pipe, but I can tell you that 3" Moto-East intake connects directly to the stock plastic pipe (which is what i'm running), and is louder than the 3" perrin with metal pipe.
The Following User Says Thank You to ajcarson11 For This Useful Post:
jflogerzi (05-08-2019)
Old 05-08-2019, 04:16 PM   #8353
86TOYO2k17
The metal pipe will enhance the whine of the 3” filter even more.
But neither are recommended unless E85 or WMI to keep Intake temps down. As the metal pipe heat soaks more then plastic and the 3” filter is basically a hot air intake.
Did you switch from metal pipe and Perrin big maf to the plastic pipe and 3” filter?
Old 05-10-2019, 12:06 AM   #8354
JDM_Import
Drives: Boosted Toyobaru
Hi,
Is anyone here able to tell me if an aftermarket mid-pipe (cat-less or high-flow) will make a difference in terms of gains? (Im currently 210 supercharged with exhaust) My header + over pipe are cat-less and my cat-back is high flow. I kept the mid pipe to stay somewhat quiet but now Im curious to know if replacing the mid-pipe for a high-flow or even straight piping will benefit at all.
JDM_Import is offline   Reply With Quote
Old 05-10-2019, 12:20 AM   #8355
86TOYO2k17
Originally Posted by JDM_Import View Post
Hi,
Getting rid of the second cat in the front-pipe will probably free up about 2whp. Jdl ultra quiet FP or hks double res FP will keep noise and drone down while losing the cat.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
JDM_Import (05-11-2019)
Old 05-10-2019, 09:31 AM   #8356
jflogerzi
jflogerzi's Avatar
Hi,
Not worth it IMO. You see gains but it will not be measureable on the butt Dyno.
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 05-10-2019, 11:39 AM   #8357
bfrank1972
Drives: 2013 FR-S Argento
Speaking of butt dyno, I'm considering going this route, what are impressions before/after?
The Following User Says Thank You to bfrank1972 For This Useful Post:
Old 05-10-2019, 12:07 PM   #8358
jflogerzi
jflogerzi's Avatar
Do it! It's a large difference even on 91 coming from oft stage 2 with catless header. When not on it you can barely tell it's even there. Drives OEM like. Throttle is much smoother from 2k to 4k on partial input because you do get some boost. On WOT 2-3k there is a decent difference but when you hit about 4k it really takes off. But everything builds very smoothly. The chassis takes the power with ease with the mods in my signature. It does produce alot extra heat. OIL cooler is a must. Or the OEM cooler + larger radiator could work for a street driven only car. I run the Jackson racing radiator and have zero issues with temps. Hoping to do my first major canyon run soon and track day. On next fill up tuner has given me the green light to fill up with e85. This should put me in the 275 whp range and 220-230wtq and on this car it's plenty fast and it's all usable.
bfrank1972 (05-10-2019)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
