Old 05-03-2019, 07:35 PM   #1
VOSS
Drives: --
Correct process for coilovers/alignment installation
I dont know if i'm overthinking this, but what is the correct process for the whole coilover, drop, alignment process?
- Install coilovers,
- Adjust height
- Wait a week to settle
- Align
- Install aftermarket wheels
or
- Install coilovers
- Adjust height if necessary
- Align
Thanks guys, first time doing this.
VOSS is offline   Reply With Quote
Old 05-03-2019, 07:41 PM   #2
i8ur911
Drives: 17 BRZ Series.Yellow
Install coilovers
Set ride height
Install wheels/tires
Alignment
No need to wait as coilover springs are typically much stiffer than standard springs and don't "settle" hardly at all.....not enough to hold off on getting an alignment.
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
The Following User Says Thank You to i8ur911 For This Useful Post:
strat61caster (05-03-2019)
Old 05-03-2019, 07:43 PM   #3
VOSS
Drives: --
Originally Posted by i8ur911 View Post
Install coilovers
Set ride height
Alignment
Thanks. Is it best to wait for the alignment before installing the new wheels to avoid uneven wear?
Old 05-03-2019, 07:46 PM   #4
i8ur911
I always highly recommend getting an alignment immediately after installing your new suspension. So ideally you should be able to install your wheels/tires at the same time as your suspension.
If you need to wait for your alignment, is drive the car as minimally as possible.
The Following 2 Users Say Thank You to i8ur911 For This Useful Post:
eastendraceshop (05-09-2019), VOSS (05-03-2019)
Old 05-03-2019, 07:47 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
depends on your situation. certain new wheel sizes will clear coilovers but won't clear the stock struts.
Old 05-03-2019, 09:25 PM   #6
VOSS
Drives: --
Alright, sweet, thanks.
Yeh, i'm not too worried about the stock struts as i'll be installing aftermarket coilovers before i install wheels.
Old 05-03-2019, 10:23 PM   #7
soundman98
soundman98's Avatar
durr... it made sense in my head somehow... you wouldn't need an alignment just changing the wheels....
Old 05-05-2019, 08:05 PM   #8
Racecomp Engineering
There's a difference between springs "taking a set" and springs sagging.
All springs take a set...even my swift coilover springs came down almost a 1/4 inch in a day. At the very least you should give the car a little drive around the block and shake it down. Installing suspension and driving directly onto an alignment rack isn't recommended.
- Andrew
norcalpb (05-09-2019), wparsons (05-06-2019)
Old 05-05-2019, 09:30 PM   #9
maslin
Benz Tech
Drives: 2017 BRZ Premium
- Andrew
Agreed. I won’t align a car immediately after it hits the ground, even if I didn’t touch the suspension. At least a lap around the block to settle things out before the heads go on.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Old 05-06-2019, 10:49 AM   #10
wparsons
wparsons's Avatar
- Andrew
Just to add a little... the spring rate of a spring also doesn't change how much or little it'll sag. You can have a very high quality, but low rate, spring that doesn't sag at all, and also have a cheap high rate spring sag a ton. Sag is more about the metal fatiguing than spring rate.
flickr
Old 05-07-2019, 04:09 PM   #11
KnightRyderx2
Drives: 2014 FR-S
Also install your new wheels before you get your alignment. This will allow the tech to compensate for the increased width and or low offset of the wheel. He can adjust the setting appropriately to fit whatever setup you have.
KnightRyderx2 is offline   Reply With Quote
Old 05-08-2019, 11:55 AM   #12
RayRay88
Drives: 2017 86 860 Special Edition
Your wheel and tire width/size/offset has no effect on camber toe or caster. -3 degrees of camber and 0toe is the same on a 16x6 wheel as it is on a 17x9 wheel.
RayRay88 is offline   Reply With Quote
Old 05-08-2019, 12:09 PM   #13
maslin
Benz Tech
He could be saying for that stance bro look you ignore actual alignment specs and set your wheels flush to your fenders.
That's a not an alignment, it's hard parking. But to each their own.
Or maybe you're planning on running a fairly aggressive wheel spec, minimum camber would be dictated by fender clearance. You may be forced to run -2.5* instead of the -1.8* you would like.
But then the heads will scratch you're shiny new wheels.
Old 05-08-2019, 04:43 PM   #14
KnightRyderx2
Drives: 2014 FR-S
Ray, when your running sizes like that you are right, you can just get a standard alignment.
I think Maslin gets what I'm trying to say here. Maybe dude is running a 18x9.5 +22(just an example), there is many setups for looks/function here. Your way of life is not someone else's way of life. At some point wheel/tire/fender engagement comes into question and you may have to compensate for it, its just a matter if his setup requires it.
If your running a more aggressive setup you may want to add a bit more camber so your tire and/or wheel will clear and not rub the fender. I mean its your choice in the end, run -1.5* and have your tire rub or run -2.3* and have it clear, its your choice.
If he has something that is not too aggressive he will be fine with whatever wheel for the alignment. On the other hand if his final wheel is on the aggressive side its a good idea to show up with that wheel. Maybe its just me but I would show up with my final wheel to the alignment just to be safe.
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
maslin (05-08-2019)
Seat installation process? Tristor Cosmetic Modification (Interior/Exterior/Lighting) 2 03-07-2018 02:00 PM
Tampa - Alignment after coilovers GalloVecchio Southeast 5 08-17-2017 11:36 AM
correct offset jonperezinsd Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 03-02-2016 02:20 PM
Correct oil filter for 86? 130 or 160/15A? kharn83 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-27-2013 01:28 AM
alignment damaged my coilovers by a well known shop 86Sam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 02-25-2013 11:59 AM
