Old 04-30-2019, 10:21 PM   #1
Suzuyans
Something something
Drives: 2017 BRZ (Vortech), 1993 R32 GT-R
Some headunit questions.
So I'm not sure how this works. Bluetooth sounds absolutely awful on my 2017 Headunit but AUX sounds great.
Is the sound quality dictated by the speakers of the car or is it the headunit? I've done a few research but I seem to get conflicting answers.
I'm also looking for suggestions for a headunit that's around 250-375 that has steering wheel controls and can use the stock backup camera.
Thank you all.
Suzuyans is offline   Reply With Quote
Old 04-30-2019, 10:39 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Bluetooth will sound bad because the headunit only supports the low quality SBC codec. For better BT quality you need a headunit that supports AAC (iOS) or APT-X (Android).
I can highly recommend the Sony XAV-AX5000 if you have an iphone (AAC support and Carplay)
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
DarkPira7e (04-30-2019)
Old 04-30-2019, 10:41 PM   #3
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
your headunit isn't the bottleneck here. the stock speakers/tweeters are pretty mediocre at best so even getting just a sub and removing the low frequencies from your speakers will improve the sound quite a bit. Either way, a Bluetooth connection is going to compress the quality of your audio hence why plugging into AUX will sound noticeably better.
..and yes, as long as you get the proper wiring harness you can retain the backup camera + steering wheel controls to the HU but be warned you do lose the stock microphone if that matters to you..
good read..http://www.ft86club.com/forums/showthread.php?t=111866
HKz is offline   Reply With Quote
Old 05-01-2019, 09:54 AM   #4
Yoshoobaroo
TRACKBREAD
Agreed, just removing the lower frequencies from the stream dramatically helps the stock speakers, even without adding a sub. I set a 100Hz low pass filter on my headunit and it sounds less muddy and still surprisingly punchy.
OP mostly complained about the Bluetooth sound though, sounds like the speaker setup is good enough for his/her taste. Unfortunately there's no way to get better Bluetooth sound from the stock headunit.
HKz (05-01-2019)
Brz headunit in a frs? Blowout17 Electronics | Audio | NAV | Infotainment 0 02-15-2017 12:15 PM
What headunit did my BRZ come with? royskopovf BRZ First-Gen (2012+) — General Topics 11 06-26-2015 08:25 AM
2014 bespoke headunit with aha questions?? 86black Electronics | Audio | NAV | Infotainment 8 09-02-2014 01:08 PM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 12:19 PM
BRZ headunit problem USB sticks & headunit reset..school me. Photonic Electronics | Audio | NAV | Infotainment 2 03-12-2014 07:06 PM
