Old 04-22-2019, 08:29 AM   #15
Timmy_Jones
Spun
Drives: 23' Supra
Originally Posted by Guru Woodman View Post
I found a great deal on a UEL Open Flash header to complement my Open flash tablet. It will be installed next week. Can't wait.
You will love it, lots of smiles coming!
Timmy_Jones is offline   Reply With Quote
The Following User Says Thank You to Timmy_Jones For This Useful Post:
Guru Woodman (04-22-2019)
Old 04-28-2019, 01:00 AM   #16
jflogerzi
jflogerzi's Avatar
Yup. Plus the oft tunes we're developed using the ofh. Great combo. If you have corn it's even better.
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Guru Woodman (04-28-2019)
Old 04-28-2019, 07:31 AM   #17
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
corn?
oh wait, E85 you mean
Probably not, it is difficult to get here.
Can't wait to upgrade. Tuesday is the day !
Guru Woodman is offline   Reply With Quote
Old 05-01-2019, 07:58 AM   #18
Guru Woodman
The UEL is installed. And it was a royal pain in the $% to get it done thanks to living in the rust belt. Two hard to access bolts were seized and needed to be cut. Which took hours
After installing the header we wanted to upload Stage 2 (plus) but my tablet gave an error.
I've tried everything but ended up opening a support ticket.
The car runs fine on stage 1 (no check engine light) but it does not take full advantage of the header.
The whole procedure was a lot ore challenging then I thought it would be.
Old 05-01-2019, 08:14 AM   #19
jflogerzi
jflogerzi's Avatar
Let the tablet do a full update on your computer. See if that clears it. If not re download the stage 2 tune and try again. You want stage 2
Guru Woodman (05-01-2019)
Old 05-01-2019, 08:17 AM   #20
Guru Woodman
Yes, I tried that. I even used a different computer to update the tablet again thinking that it might be that. I also downloaded the tunes again and installed them but it didn't clear it.
Old 05-01-2019, 08:18 AM   #21
jflogerzi
jflogerzi's Avatar
Wierd but you can flash stg 1... That makes zero sense
Old 05-01-2019, 08:21 AM   #22
Guru Woodman
I have been running the stage 1 flash for a couple of years now. So it has been a while since I installed it. Sorry for not being clear.
Now I can't install anything. I get stuck at this screen. It recognizes the car but if I click on Tuning I get this message.
Old 05-01-2019, 08:34 AM   #23
Guru Woodman
This was the only reference I could find:
"OFTCODE 10001 and 10002:
This error is due to the protocol file on your OFT being out of date, or missing for some reason. Please use OFM to update your OFT, and then try to read your ECU again. If the problem persists, use the contact form on our website to request assistance."
Old 05-01-2019, 08:38 AM   #24
jflogerzi
jflogerzi's Avatar
I would flash back to stock. Then wipe and delete the OFT. Remove the software from your computer. Reinstall and connect the OFT to your computer. Let it update and put the the stage 2 tune back on and try to flash again.
Old 05-01-2019, 08:41 AM   #25
Guru Woodman
I thought of that but I don't think I can flash back to stock.
My stock tune is on the OFT, but as soon it checks the current tunes on the OFT I get the error
Old 05-01-2019, 08:42 AM   #26
Guru Woodman
thanks for thinking with me btw
Old 05-01-2019, 11:08 AM   #27
elBarto
elBarto's Avatar
Drives: Toyota GT86
Try also updating the template file
Template for OFT v1
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 05-01-2019, 12:47 PM   #28
Guru Woodman
Template for OFT v1
Tried this. No change. my startup screen is slightly different but I still get the same error.
Alignment Shop in SD and quick question question JohnTran619 Southern California 5 11-21-2018 01:40 PM
Quick Question JG Scion FR-S / Toyota 86 GT86 General Forum 1 06-14-2015 06:14 PM
Quick Question trsiidno Forced Induction 7 01-09-2015 09:48 AM
Quick question?!?! tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-18-2014 02:55 PM
JDL EL header sound, quick clip. Hardrock4445 Engine, Exhaust, Transmission 20 03-29-2013 06:08 PM
