| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: frs
ball joint leak
2013 frs 125k.
1 in lowered on coils some negative camber from camber bolts. The boot is ripped and leaking grease on one side. But no play in the ball joint yet. Do i have to replace the whole control arm? Does anyone sell just the ball joint? |
#2 |
I only see complete arms with the ball joint for sale on rockauto, but honestly that's what you want anyway. Have you ever replaced a ball joint? It can be a real pain in the ass, and the tool to do it is at least $150 for a half-ass decent one that won't tear out the threads immediately.
While you're at it, you might go for aftermarket arms that are adjustable, depending on your build goals. |
| The Following User Says Thank You to Tristor For This Useful Post: | humfrz (05-01-2019) |
#3 |
I believe Subaru discontinued the ball joint as a part number a while ago. They only sell the whole control arm now.
13 BRZ Limited 6MT Lightning Red
#4 | |
Drives: frs
#5 |
Drives: 2013 WRB BRZ
Rockauto has them for $136. OEM replacements. No fancy adjustable parts.
https://www.rockauto.com/en/catalog/...trol+arm,10401
#6 |
Benz Tech
Drives: 2017 BRZ Premium
125k if it needs a balljoint, it needs caster and camber bushings as well.
Do the whole arm, in and out in 20 minutes Last edited by maslin; 05-01-2019 at 12:12 PM. |
| The Following User Says Thank You to maslin For This Useful Post: | Tristor (05-01-2019) |
| LCA Upper Ball Joint Issues (maybe?) | NAEightySix | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 11-03-2017 12:31 PM |
| Tie rod ball joint stuck | Killianti | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 07-19-2015 10:32 PM |
| Ball Joint Replacement, The fun way. | FRSPacNW | DIY (Do-It-Yourself) Guides | 2 | 06-28-2014 03:04 AM |
| Front ball joint dimensions | J-W | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-02-2013 05:31 PM |
| loose ball joint | Grip Ronin | Issues | Warranty | Recalls / TSB | 15 | 07-09-2013 01:16 PM |
