Old 04-29-2019, 09:56 PM   #15
Originally Posted by gravitylover View Post
The snout could be scored too.
Here's a picture of my old one. Doesn't do it justice but that's only about 15 Kmi.
I've been mulling over this idea for a while.
gravitylover (05-01-2019)
Old 04-30-2019, 05:48 AM   #16
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Originally Posted by FR-Sky View Post
I think i have this problem too.
While i the clutch was in traveling motions, it has this little knock or tick sound whatever u call it
I hear that one too, but I think it's linked to the pedal assembly. Definitely coming from inside the cabin, maybe the clutch release switch?
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
FR-Sky (04-30-2019)
Old 04-30-2019, 05:48 AM   #17
alex87f
Meow
alex87f's Avatar
Originally Posted by VenomRush View Post
The notchiness (not sure if thats a word) of the pedal was happening after i adjusted the clutch pedal back to the stockish position. I adjusted it back to a low engagement point (clutch pedal about 2-5mm above the brake pedal) and havn't had the notchy crunchy feel in the pedal ever since. Definitely not a fix.
I'm confused, it's not a fix, but it solves the issue permanently?
Old 04-30-2019, 05:49 AM   #18
alex87f
Meow
alex87f's Avatar
Originally Posted by ermax View Post
This is a common problem on all cars. If the dirt gets into the grease on the shaft or dries out then it’s going to feel notchy. You can try cleaning the fork externally and then reapply the grease but most likely you will need to drop the tranny and clean up the whole shaft. You will not need to bleed the system to do this job.
So it can't be done from the top of the transmission?
Another cause of a notchy feel could be pockets of air in the line cause by a bad master or slave. Is your fluid dark? If so then the rubber seals in the master or slave are going bad.
The fluid we bled was clean and the one in the tank is brand-spankin' new (maybe 200 miles on it).
I lubricated every articulation I could find in the pedal assembly with WD40, and added some where the slave piston meets the fork actuator (which is dirty AF). Will report back if this helps.
Old 04-30-2019, 11:02 AM   #19
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
not a fix in a sense that if i put it back to the original clutch pedal position, it would probably happen again.
VenomRush is offline   Reply With Quote
Old 04-30-2019, 12:56 PM   #20
It is the pedal assembly. Loosen and re-torque the screws holding it in place. It'll fix it for a while. I vaguely remember talk of a TSB but... Personally, I'd look for where the bracket isn't seating properly and, if I could find a point where tightening a screw forces a flex, I'd stick a washer in between it and the firewall.
FR-Sky (04-30-2019), jcw99 (05-01-2019)
Old 04-30-2019, 01:50 PM   #21
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Do you have some kind of pic or some sort?
Not a very good mechanic XD haha
IG: @rearwheelclub
FR-Sky is offline   Reply With Quote
Old 04-30-2019, 01:59 PM   #22
I don't. The best way to learn is by just getting in there on your back with a flashlight. Service manual is your best friend. Look in my sig line. It'll be under drivetrain>clutch>clutch pedal>components
FR-Sky (04-30-2019)
Old 04-30-2019, 09:34 PM   #23
Now THAT, I want to see, there - big guy -
Old 04-30-2019, 09:45 PM   #24
I'm a little bit slower getting back up but, yeah. I still got it.
gravitylover (05-01-2019), humfrz (04-30-2019)
Old 04-30-2019, 10:00 PM   #25
Give him some room folks, ol Ultramaroon is about to crawl into the footwell and show you how to fix the pedal assembly -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
gravitylover (05-01-2019), jcw99 (05-01-2019), Ultramaroon (04-30-2019)
Old 04-30-2019, 10:33 PM   #26
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Again why did I read that in a sexual way?
Maybe all this shaft, and sticky talk.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
humfrz (05-01-2019), Ultramaroon (04-30-2019)
Old 04-30-2019, 11:52 PM   #27
Well, it IS @humfrz.
humfrz (05-01-2019)
Old 05-01-2019, 12:47 AM   #28
there, Mr.ac , maybe if you spent more time out on the lot, trying to sell those Civics, and less time sitting at your desk reading girlie magazines, that you keep in your top drawer, maybe you wouldn't be having those thoughts -
Clutch Pedal Travel Stopper (CPTS) Modification JDKane527 DIY (Do-It-Yourself) Guides 35 01-26-2019 03:37 PM
Clutch Squeaks at the end of travel... clutch fork? treminaor Issues | Warranty | Recalls / TSB 54 12-02-2016 03:53 AM
when I go to great travel reinketrx Off-Topic Lounge [WARNING: NO POLITICS] 0 06-12-2016 06:26 AM
How To: BRZ infinite 1-5 headlamp adjustment(no more notches!) soundman98 DIY (Do-It-Yourself) Guides 7 01-27-2015 11:10 PM
