Old 01-15-2019, 03:25 PM   #141
Ashikabi
Ashikabi's Avatar
So you are cutting a hole in your hood because you don't have a mirrored turbo?
The Following User Says Thank You to Ashikabi For This Useful Post:
spitsnaugle (01-15-2019)
Old 01-15-2019, 10:47 PM   #142
kurty85
Drives: 2014 FRS LS Swap
Yes due to the turbo being higher on the left side. But it is not a hole. It will be like a DSM with a small rounded hump. Little less expensive than trying to source a set of mirrored turbos with vband housings that will fit. Precision only makes the mirrored size in 6266/6466/7675 anyway. Either way you look at it, this was way easier.
kurty85 is offline   Reply With Quote
Old 01-15-2019, 10:53 PM   #143
Ashikabi
Ashikabi's Avatar
Right. I just wanted to be sure I saw that right
Old 01-22-2019, 06:09 AM   #144
kurty85
Decided to go with a bigger radiator and had to modify the entire front end because it is to tall and will hit the turbos. I cut the old radiator mounts off and came up with a solution for the radiator and intercooler. Radiator will be the Be cool 35223. 3" thick core, 28.5x17 with 2780 cfm fans.
Sent from my SM-G950F using Tapatalk
The Following 2 Users Say Thank You to kurty85 For This Useful Post:
Sportsguy83 (01-23-2019), Zer0 (01-22-2019)
Old 01-26-2019, 06:26 AM   #145
kurty85
Today was max effort for little gain. The brace i was trying to make for the top of the radiator turned out shitty but i have extra material so i can make another one. The turbo oil drains are too high in the front cover so after much thought i decided to put them in the oil pan. 13 bolts, 3 allens, oil filter housing, oil filter, steering rack, subframe, subframe braces, sump pickup tube, balancer, front cover, dipstick, and waterpump i got the oil pan off. Will be drilling and welding the pan tomorrow. Plus i have to get this gold iridite coating off before i weld it. Here is how it sits.
Old 04-27-2019, 01:06 AM   #146
kurty85
Got most everything reassembled. Have to get some wastegates, little more coolant piping, ic piping, and make the downpipes then ill start it. Also got the drift armor bar back from powdercoating and it came out nice.
The Following User Says Thank You to kurty85 For This Useful Post:
Zer0 (04-27-2019)
Old 04-27-2019, 11:42 AM   #147
Zer0
Drives: 2015 frs
Looking much cleaner now.
Zer0 is offline   Reply With Quote
Old 04-27-2019, 04:08 PM   #148
kurty85
After I install the wastegates and downpipes and get everything set, I will send all the hot side parts including turbos to swaintech for their white lightning coating:
http://swaintech.com/race-coatings/a...s-price-sheet/
No more rusty parts after that and the best heat coating available.
Thinking of powdercoating the ic piping or I wonder if there is a better way to do it?
Old 04-27-2019, 05:41 PM   #149
Ashikabi
Ashikabi's Avatar
Really isn't a better coating than powder. If you want crazy colors look at Prismatic Powders.
Old 04-27-2019, 11:28 PM   #150
kurty85
I was meaning about heat reflection coatings for ic pipes. Not the gold tape that does nothing.
Old 04-28-2019, 02:41 AM   #151
Zer0
Drives: 2015 frs
They make reflective aluminized sleeves, and wraps to cover tubing and hoses. It won't look as nice as powder coating, and honestly I'm not sure which one would work best. I was looking into a product from thermotech.
Old 04-28-2019, 07:02 AM   #152
kurty85
I saw those. They look like hooker boots. Think ill just powdercoat everything since it doesnt seem to make a difference in temps. Working on finishing the coil pack relocation now also. I mounted cbm motorsports coil brackets in the fenderwells last year and left them until now. Now i have a reason to use them.
Old 11-30-2019, 09:23 PM   #153
kurty85
Got the headers back. Fully welded now. Modified turbo filters to fit. Installed everything for last test fit. Downpipes are last thing. Intercooler pipes are done and at powdercoating. After downpipes, all hot parts will go to swaintech.
Sent from my SM-G973U1 using Tapatalk
The Following 4 Users Say Thank You to kurty85 For This Useful Post:
DustinS (12-02-2019), Irace86.2.0 (03-20-2020), Sportsguy83 (12-02-2019), Zer0 (12-01-2019)
Old 12-01-2019, 12:45 PM   #154
Ashikabi
Ashikabi's Avatar
This is beautiful
kurty85 (12-01-2019)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Not just another ls swap killin'_for_a_livin' Member's Car Journals 7 08-28-2016 04:58 PM
WRX SWAP!!! PowderfaceTr. BRZ Photos, Videos, Wallpapers, Gallery Forum 1 02-24-2015 06:29 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 07:59 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
