Old 04-26-2019, 08:21 AM   #1
Gundler
Drives: 2017 Toyota 860
Help needed with wiring configuration
Looking to see if anyone has an image of the E8 connector to the master switch in the driver’s side door...made the mistake of pulling the wires out of the connector. I did follow the wiring charts as seen from this site, but the auto up/down switches are blinking with the auto up/down not working on driver’s windows and passenger not working at all from this switch (the passenger switch works just fine). I did follow the procedure to reinitialize, but this has proven unsuccessful. Any help/guidance would be appreciated.
Gundler is offline   Reply With Quote
Old 04-26-2019, 09:20 AM   #2
Try disconnecting the battery for a couple of minutes. The procedure is for the jam protection so may not be enough to work for a whole reset.
Old 04-26-2019, 09:40 AM   #3
Gundler
Thanks for suggestion...I did disconnect the battery for about 5 minutes and then performed the re-initialization procedure with no luck.
The Following User Says Thank You to Gundler For This Useful Post:
Tcoat (04-26-2019)
Old 04-26-2019, 09:41 AM   #4
Worth a shot.
2012 Lexus LFA Configuration III JPxM0Dz CANADA 15 12-25-2015 01:03 AM
Backseats and divider configuration Fastbrew Cosmetic Modification (Interior/Exterior/Lighting) 10 08-03-2014 11:51 PM
Dash Panels now available in RHD configuration. JPM Coachworks Announcements, Contests, Giveaways 0 06-06-2013 01:22 PM
Moto-East BRZ/FR-S Tuning and On-Line Configuration tool! Xero-Limit Announcements, Contests, Giveaways 2 03-25-2013 04:24 PM
P8400 Aftermarket deck HELP NEEDED WITH WIRING iamkyle Electronics | Audio | NAV | Infotainment 1 01-13-2013 04:41 AM
