Old 04-23-2019, 07:25 PM   #1
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Koni Sport Yellow damper feedback
I'm interested in the Koni Sport Yellow adjustable dampers and would appreciate feedback from those having experienced them.
A few questions;
-can the adjustment range allow a soft / comfortable DD setting?
-any longevity issues? What is there lifespan?
-any comments positive or negative?
-would you do them again?
Thanks in advance for your constructive feedback.
Muskoka800 is offline   Reply With Quote
Old 04-23-2019, 07:46 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I've run Koni and Bilstein on the E36 and the NA Miata chassis. Koni is very nice for the adjustability. Bilstein seem to be a better quality, I'd honestly go with a dedicated coilover if you need dampening adjustments constantly.
I loved the Konis that I had, but think consistently I found the Bilsteins to be less bouncy, maybe partially because I wasn't constantly tampering with the dampening adjustments.
I had the Bilsteins on my E36 for about 87,000 miles, and they were still pretty good. Longest I've run konis was about 20k, which was on my Miata. I sold the car because I got sick of bottoming out. Really nothing bad to say about either - but the Konis are expensive and the paint chips easily on them.
Keep in mind, this experience is with two other platforms, and is from 10 years ago - they may have improved things, but really the issue with adjustability is just that - you may never be content, and you're more apt to stress yourself out changing things, than just accepting it and making the right choice initially.
churchx (04-24-2019)
Old 04-23-2019, 08:00 PM   #3
CoolHandMoss
Drives: 2013 FRS
Konis last a very long time under normal use. They also have a lifetime warranty.
My biggest complaint about konis is that they can't be revalved. Or rather, revalving options are very limited depending on which model of Koni you have. I doubt I would ever get konis again. I would rather run bilsteins and get them custom valved if I were tempted to get konis again. Unless I end up racing in ssc of course. Then I'd buy Konis again.
CoolHandMoss is offline   Reply With Quote
Old 04-23-2019, 09:10 PM   #4
cueball89
Drives: 15 Impreza
What are you trying to change about your car and what is your intended use for it?
I had 2 sets of koni inserts on my wrx.
The rebound could be adjusted quite soft and turned up beyond the point of usefulness for my spring rates of ~250lbs/inch.
The first set lasted ~100,000 miles and the 2nd set lasted~75,000 miles.
Get the full strut and not the insert. You lose bump travel with the insert. The valving isn't as refined as my rce ss1 coilovers. Certain impacts with the konis were harsh, I don't have that issue with my coilovers. Bilsteins weren't an option for my wrx. Id try the bilsteins just to be able to compare them as everyone seems to rave about them.
cueball89 is offline   Reply With Quote
The Following 4 Users Say Thank You to cueball89 For This Useful Post:
Racecomp Engineering (04-24-2019), strat61caster (04-24-2019), Tatsu333 (08-17-2021), wparsons (04-24-2019)
Fortune auto 500 coilovers vs. RCE Yellow springs + KONI Yellow shocks Kyogre Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 05-12-2015 04:59 PM
RCE Yellow springs with Koni Sport adjustable shocks TimR Brakes, Suspension, Chassis 7 03-05-2015 02:14 PM
Koni Yellow Sport shocks on sale with FREE SHIPPING!! Plus Ground Control coilovers! Moddiction Brakes, Suspension, Chassis 52 08-26-2014 02:07 PM
FS: swift springs (brz spec) with koni yellow sport shocks Mersd Brakes, Suspension, Chassis 8 04-20-2014 06:12 PM
GB: Koni Sport Yellow Shocks/Struts - CRAZY PRICING - FREE S&H - IN STOCK! AJ@ECSMotorsports Groupbuys 13 09-15-2013 08:21 AM
