Old 04-21-2019, 06:30 PM   #15
toast
Drives: 14 BSP Edelbrock BRZ
Spray paint is absolutely different from automotive paint. Anything on a car is a 2 part epoxy with a base and activator. The activator creates a chemical reaction to cure the paint. Almost anything out of a can will simply be a lacquer that 'cures' by a volatile compound evaporating. Put the volatile back and it should come right off. I would clay bar the area first, then use a microfiber towel and take it off with acetone, work in small areas and don't push hard, let the chemical do the work. When you are done you will need to rewax the car, the acetone will have taken any protective products off the car.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
Spuds (04-21-2019)
Old 04-21-2019, 07:00 PM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
see? if you ever need the correct info, instead of dozens of anecdotal ideas, just post the wrong info matter-of-factly, and suddenly the right info appears out of thin air!
Spuds (04-21-2019)
Old 04-21-2019, 07:15 PM   #17
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
why do people think alcohol will remove paint? Alcohol will not touch enamel (or cured acrylic for that matter).
The best bet would have been to deal with it before it cured but pretty much screwed at this point I am afraid.
You could try a bit of nail polish remover. It is a diluted acetone that could very well remove much of the dried paint without destroying the cured acrylic underneath.
Shit, that's what I meant.
Old 04-21-2019, 08:31 PM   #18
The car paint is an acrylic or water based polyurethane not an "epoxy" and I don't believe Subaru uses a two part base coat but it is possible. Any other paint that can get on it could be an enamel, an acrylic, a urethane, or a lacquer. There is no telling what was in the spray can he ran over. Pure acetone may be a bit harsh but it will work with just about any type of coating. That is why I said the nail polish remover since it is diluted acetone and has a lower risk of stripping the clear coat off the car. Not sure what the advantage of clay baring first would be since that just pulls impurities from paint not strips it.
Old 04-21-2019, 09:10 PM   #19
toast
Whether it is solvent based or water based modern automotive paint is a base coat and clear coat. The clear coat is absolutely a two part mix, otherwise it would have even worse durability than it does now. The only two part spray cans that exist are made by SprayMax and cost $24 a can, it is what I use when I'm doing small projects and don't want to have to clean out my spray gun. The likelihood of him running over an activated can of spraymax that hasn't already gone through its pot life of 48 hours is pretty close to zero. So I don't care what he ran over, acetone will take it off and it will not affect his clear coat. Clay barring would take off any of the paint that isn't really adhered well.
Old 04-21-2019, 09:22 PM   #20
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Pretty sure it's a new can. Btw guys I posted the can if paint I ran over in the link. I went back to the scene to look at it. And I will be visiting my detailer tomorrow. Thanks.
Sent from my SM-G9600 using Tapatalk
Oxyg3n is offline   Reply With Quote
The Following User Says Thank You to Oxyg3n For This Useful Post:
humfrz (04-22-2019)
Old 04-22-2019, 12:37 AM   #21
Spray paint is absolutely different from automotive paint.....
Not everywhere, ain't never been ta West Virginia have ya -
Dadhawk (04-22-2019)
Old 04-22-2019, 11:27 AM   #22
A two stage (base and clear) is not the same thing as a two part finish. I can not find anything that says the clear coat on Subarus are a two part finish. If they are it is pretty rare. You have something that shows it is a two part coating?
Old 04-22-2019, 11:50 AM   #23
@Oxyg3n Straight from Rustoleum…
https://www.rustoleum.com/project-ca.../paint-on-car/
RickyBobby (04-25-2019), soundman98 (04-22-2019), Tcoat (04-22-2019)
Old 04-22-2019, 03:58 PM   #24
toast
Every clearcoat that is on a car made in the last 20 years is a polyurethane; it is chemically created by mixing a polyol and a polyisocyanate. Manufacturers used to use polyester polyols to make their paint. This was back when you could drive a car on a sandy road and not have all the clearcoat chip off like you do now. The downside is that while the activator (the '-cyanate' part) is universally nasty the polyester polyols are also not that great for the general health of the planet. At some point, when varies by manufacturere, they switched to acrylic polyols which are water-based and slightly less likely to kill everything that catches a whiff of the fumes used to paint.
Old 04-24-2019, 07:50 PM   #25
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
I'm excited to see how this works out, if you don't get it sorted I suggest reaching out to ChrisFix. It'd make for an entertaining video to add to his YouTube collection.
slizoth is offline   Reply With Quote
Old 04-25-2019, 07:11 AM   #26
RickyBobby
Drives: 2013 Firestorm FR-S AT
Great stuff, have used it before when my car got oversprayed. I would stay clear of acetone. It's one of the main components of commercial paint remover.
MSDS: https://www.fastenal.com/productimag...INC_882026.pdf
You could also try mineral spirits. It will not harm the clear coat. https://www.homedepot.com/p/Klean-St...4005/100251041
Over the counter alcohol, IPA, will not remove cured paint.
RickyBobby is offline   Reply With Quote
AutomotiveTouchup Paint Experience? megamarines Cosmetic Modification (Interior/Exterior/Lighting) 3 09-09-2015 10:18 AM
Best way of removing Bugs without damaging paint? tacoss23 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 10-01-2013 12:13 AM
Anyone else experience paint peeling? euroshowoff Issues | Warranty | Recalls / TSB 9 08-23-2013 11:39 AM
Paint Correction, Opti-Coating, Car Wraps, Paint Protection & Tinting - LI Detailers LI Detailers Cleaning and Detailing 1 12-27-2012 04:12 PM
paint restoration : Subaru WRX - bringing the paint back to life brianc Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 06-25-2012 01:23 PM
