Old 07-17-2012, 03:25 PM   #15
raz0rbladez909
I'm here for the beer
raz0rbladez909's Avatar
Drives: 2013 Scion FRS, 1971 Datsun 240z
Originally Posted by Synack View Post
There probably aren't any kits that fit the stock connector. Does anyone know if the Scion tC and xB have the same harness connector as the FR-S? That would save a lot of trouble.
It's just a H11 bulb, nothing different than the tC . Usually it's just with the really cheap or "universal" kits that only come with the standard prong types that require you to do this. Any slightly above average company should send out the proper H11 connectors.
raz0rbladez909 is offline   Reply With Quote
The Following User Says Thank You to raz0rbladez909 For This Useful Post:
RRnold (07-17-2012)
Old 07-17-2012, 03:27 PM   #16
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by raz0rbladez909 View Post
It's just a H11 bulb, nothing different than the tC . Usually it's just with the really or "universal" cheap kits that only come with the standard prong types that require you to do this. Any slightly above average company should send out the proper H11 connectors.
Oh are you saying every good H11 connector is the same for the bulb connector to the factory harness?
Like I'm trying to see if these would work.
http://www.ebay.com/itm/Xenon-5000K-...ht_5740wt_1139
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-17-2012, 03:57 PM   #17
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Retrofit Source, 3B Specialties all offer "complete" connectors!
tonystewart is offline   Reply With Quote
The Following 2 Users Say Thank You to tonystewart For This Useful Post:
RRnold (07-17-2012), tripjammer (07-26-2012)
Old 07-17-2012, 04:01 PM   #18
raz0rbladez909
Yes, all cars that use H11 bulbs will also be using the same connector. I can't view ebay while at work but typically most of those universal kits are made in the same place. I would personally look for something that offers a warranty because it is common for those kits to have bad components.
Old 07-17-2012, 04:05 PM   #19
Synack
Boosted
Synack's Avatar
Drives: Sideways
This one has 2 year warranty and 7 day return on DOA items. Sounds good to me.
Old 07-17-2012, 05:09 PM   #20
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
If you are going to with a PnP HID kit, might as well get the kit with the oem connectors. That's how you can tell the lower grade kits from the decent ones.
Old 07-17-2012, 05:13 PM   #21
Synack
Boosted
Synack's Avatar
Drives: Sideways
Right but how can you tell if the kit has the OEM connector or not. There are none out there designed for the FR-S under $100. And I'm sure theres thousands of generics that'll fit but nobody has yet to answer that question. I'm not about to buy one of our vendor's slim versions that basically the same setup as one on eBay but three times the price. As long as everything clicks and works for 4+ years I'm good.
Old 07-17-2012, 06:04 PM   #22
RRnold
2 wheel member
RRnold's Avatar
They are all made in China but I know DDM and Slim Cubby have the H11 kits that have the oem connectors.
Old 07-17-2012, 08:02 PM   #23
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I have always used DDM Tuning's HID kits. They have a lifetime warranty and cost $50 for a 55w kit. I have had them in my MR2 for almost three years now with zero problems.
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 07-23-2012, 02:12 PM   #24
TRD_86
Drives: 2013 86 white
Does the 55w ballast consider to create too much heat for the housing projector for this car or should I take 35w to be safer ?
TRD_86 is offline   Reply With Quote
Old 07-23-2012, 03:31 PM   #25
tonystewart
The 35W will give you more light than you can use, are you trying to spot caribou at a mile?
Old 07-23-2012, 08:15 PM   #26
Synack
Boosted
Synack's Avatar
Drives: Sideways
Here's my 50w at 5000k.
Everyone says it looks great and stock and looks like the car came this way. Looks better in person.
The Following 2 Users Say Thank You to Synack For This Useful Post:
BabaYaga (10-11-2014), tripjammer (07-26-2012)
Old 07-24-2012, 01:50 PM   #27
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
It does look good. Did you have to point down your projectors? I installed HIDs in mine and they point pretty high. I need a flat place to adjust them...
phanguy is offline   Reply With Quote
Old 07-24-2012, 02:06 PM   #28
Synack
Boosted
Synack's Avatar
Drives: Sideways
I haven't done anything yet. I still have yet to test it at night lol.
leather seat conversion stalon320 Interior Parts (Incl. Lighting) 6 07-20-2012 04:36 PM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
LED exterior and turn signal conversion fenton Cosmetic Modification (Interior/Exterior/Lighting) 0 06-07-2012 11:33 PM
Anyone ever heard of a coupe to removeable hard-top conversion shop? Saibot CANADA 26 02-09-2012 10:38 PM
