Old 04-14-2019, 06:35 PM   #57
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
The first event planned is the SCCA Majors in Portland on May 18th. I may go to a Conference event on May 5th only because of how little value I got out of the TnT.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
Rampage (04-14-2019)
Old 04-16-2019, 04:10 PM   #58
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by rice_classic View Post
Lessons learned from test day:
[LIST]
[*]I can't heel-toe in race conditions with pedals in OEM positions. I can on the street but the needs from the pedals during threshold braking is different. I need to widen and raise the accelerator pedal.
You can fit a 10mm spacer under the throttle pedal assembly and still have plenty of stud to mount the pedal. I had to do this on my car since I have girlish sized feet. I also run the Cusco throttle pedal plate. Much easier to heel toe now.
You mentioned in another post pulling the fuel pump fuse to crank the car for oil pressure. If you hold down the throttle pedal while cranking it shuts off the injectors.
Old 04-21-2019, 02:40 AM   #59
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
What size are those RE71Rs? I could be interested in buying them if you end up selling them.
mistople is offline   Reply With Quote
Old 04-22-2019, 01:39 PM   #60
rice_classic
Verus spacer and Cusco Pedal plate both installed now, can't wait to try them out. I appreciate the tip about shutting off injectors - I did this yesterday on the Motorhome (2011) as I started it up for the first time in 6 months - worked great. Thanks!
IMG_0661 by Rice Classic, on Flickr
I am open to this. They are 245/40/17. They have 5 (barely) dry laps on them - they are effectively brand new, I just heat cycled them for you. Let's sync up via PM and work something out.
IMG_0664 by Rice Classic, on Flickr
PRO86 | WTCC | STL
Old 04-22-2019, 01:53 PM   #61
rice_classic
It's done, now it's time to drive.
All the little things I needed to remedy are now remedied - pedals, alignment, new rotors, seat position and decals... All I have left to do now is play with it. Looks like life has got in the way of that for next few weeks so my 'real' test will actually be at the Majors weekend in PIR.
"It's the little things" - like the little roll-bar attachment from Ram-Mount used with the AIM Solo works great and I was able to put the solo is an optimal place.
IMG_0663 by Rice Classic, on Flickr
Finished product:
IMG_0662 by Rice Classic, on Flickr
PRO86 | WTCC | STL
The Following 6 Users Say Thank You to rice_classic For This Useful Post:
Lonewolf (04-26-2019), NoHaveMSG (04-23-2019), Pat (04-22-2019), Rampage (04-23-2019), treedodger (04-28-2019), Tristor (04-29-2019)
Old 04-23-2019, 08:13 PM   #62
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Looks like a racecar now!
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 04-26-2019, 07:13 PM   #63
Lonewolf
Lonewolf's Avatar
Drives: Moped
Any finished pics with wheels/tires mounted on the car?
Old 04-28-2019, 11:42 PM   #64
rice_classic
Here you go!
IMG_0667 by Rice Classic, on Flickr
IMG_0666 by Rice Classic, on Flickr
PRO86 | WTCC | STL
The Following 5 Users Say Thank You to rice_classic For This Useful Post:
chickunfut (05-08-2019), Lonewolf (05-05-2019), Rampage (05-12-2019), treedodger (04-30-2019), Tristor (04-29-2019)
Old 05-12-2019, 05:56 PM   #65
Rampage
Rampage's Avatar
The car looks great. I am looking forward to a report from your first T4 race. Will you be recording video?
Old 05-13-2019, 02:16 PM   #66
rice_classic
I was able to find the time to get to a Conference race yesterday (not SCCA) because my friend and fellow racer was able to take my truck/trailer/car to the track for me while I was out of town (what a guy!).
So this was my first competition event in the car after I just figured out the alignment. The class I was in was CT4, which is a Conference specific class that allows: SCCA T4 cars, PRO3 (e30s) and PRO44s (944s). It makes for a large class of similarly paced cars.
I finished 2nd to last - but only 2 seconds separates 9 cars and that's VERY cool. Important items to note... Pacific Raceways had the back section re-paved making the track about 1 second faster for folks who can figure out the new lines. The previous track record in SCCA T4 is a 1:38 flat set by Oscar Jackson. I was able to click off a 1:37 flat and I'm still sorting out the car/driver setup. I think the car can do mid 35's but the driver will probably only see mid 36's. The video is being uploaded now to youtube - should have it posted later today, where you can watch me drive cautiously for 30 minutes.
The T4 lap record at Pacific Raceways will be reset in 2 weeks at the SCCA Majors by someone - I'd like it to be me but I don't think that's in the cards. Nonetheless there are 6 T4 cars registered for that race and it's sure to be a terrific event.
IMG_0710 (2) by Rice Classic, on Flickr
PRO86 | WTCC | STL
The Following 3 Users Say Thank You to rice_classic For This Useful Post:
NoHaveMSG (05-13-2019), Rampage (05-13-2019), strat61caster (05-14-2019)
Old 05-13-2019, 03:04 PM   #67
Rampage
Rampage's Avatar
Link to video when it is done uploading please?
Old 05-13-2019, 05:07 PM   #68
rice_classic
The 'hypersmooth' on the gopro was turned on so you get this weird pendulum effect from the camera. This cool thing is that the steadiness really shows how bumpy some of the track is as you can see the car undulate within the frame.
The red/white e30 with no brake lights threw me off for a bit. I was like "how is he not using his brake there!?!"... then I realized. [ame]http://youtu.be/m4QYk46IJ-8[/ame]
I'm not seeing the video as getting embedded on my computer so just in case that's happening to others, here's the link:
PRO86 | WTCC | STL
The Following 4 Users Say Thank You to rice_classic For This Useful Post:
Evan55 (05-14-2019), NoHaveMSG (05-13-2019), Rampage (05-13-2019), SCFD (03-09-2021)
Old 05-15-2019, 11:11 AM   #69
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I was going to come out this weekend even though HPDE got canceled but I got busy.
I know it is not the fastest because how it upsets the car, but I love taking a bunch of curb at 5a
rice_classic (05-15-2019)
Old 05-15-2019, 01:19 PM   #70
rice_classic
I'll be down at the Portland SCCA Majors are this weekend at PIR (Then next weekend at Seattle).
There's a Track Night in America on Friday night that you can attend if you want to get on track. https://www.tracknightinamerica.com/...ortland-may-17 Looks like registration is via SCCA instead of MSR.
You and any other FT86 folks in Oregon are invited to stop by my (humble) motorhome, have a beverage and chat. I'm only coming down and setting up Friday evening but Totemo_Hayai will be doing the TNIA with his new T4 FRS which will be its maiden voyage in preparation for the race weekend.
Sat/Sun are expected to be wet and dry which will make for some interesting racing.
edit: After the Majors races in Seattle in a couple weekends, I'll post a final update on this thread and detail where the car is, where I need it to be and ultimately - what it cost to complete along with avg-per-weekend cost of operation.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
NoHaveMSG (05-15-2019), Rampage (05-15-2019)
SCCA T4 Race Car Build - Suspension ccdrift Tracking / Autocross / HPDE / Drifting 10 11-11-2018 12:50 PM
Daryl Harr's FR-S SCCA Race Car Build driver71 Member's Car Journals 39 05-28-2016 04:50 PM
VADERR's Tie Fighter (C Street SCCA Build) VADERR Member's Car Journals 49 02-10-2016 12:31 PM
My SCCA National budget RTR build SeanRTR Tracking / Autocross / HPDE / Drifting 69 09-05-2014 12:49 PM
Bad Panda Motorsports - SCCA Solo STX BRZ Build BadPanda Member's Car Journals 7 06-13-2013 01:08 AM
