Old 04-28-2014, 11:45 PM   #15
MyEvilMonkeys
Drives: 2013 Scion FRS
Everything checked out. The ball joints were tight and flex smoothly. Checked the torque on all nuts. I ran by the dealer and had the service foreman take a quick circle around the lot and he scheduled an appointment for next Tuesday to see what they can find. He described it as a possible body flexing noise vs more suspension related. We'll see. They were ok with the changes in suspension I made. and to my surprise didn't try blaming those changes immediately. Standby for and update next week.
MyEvilMonkeys is offline   Reply With Quote
Old 05-07-2014, 10:30 AM   #16
MyEvilMonkeys
Mystery solved. Apparently the strut bars that attach to the firewall were loose. They have been that way since i bought the car cause I've had the pop noise for a long long time and it's just become intolerably worse. I can't believe i missed it. I had yanked on it several times and nothing appeared loose, but i never bothered checking the torque on them since i had never removed the bars or touched any of those bolts. Dealer was very cool about it, no charge and they didn't treat me like garbage or blame my suspension modifications. Nothing but compliments on the car from the service techs and manager. Not all dealer experiences are bad. Disappointed the suspension shop that did the alignment couldn't find the issue. Anyways, super simple issue resolved. Thanks to everyone that offered help and suggestions!
The Following 3 Users Say Thank You to MyEvilMonkeys For This Useful Post:
humfrz (04-16-2019), Superhatch (09-12-2014), WRB-DZA-BRZ (02-25-2016)
Old 05-08-2014, 09:08 AM   #17
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I need to check that, I get the same type of noises over rough roads and low speed sharp bumps. Possibly I have the same issue.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-16-2019, 06:52 AM   #18
maicolp
Drives: toyota gt86 1st edition
i'll check that too
what's the torque needed to tighten those?
maicolp is offline   Reply With Quote
Old 04-16-2019, 02:29 PM   #19
Originally Posted by maicolp View Post
i'll check that too
Bubba says - just medium tight.
humfrz for Bubba
Old 04-16-2019, 02:32 PM   #20
humfrz for Bubba
Middlin'. Bubba would never say "medium".
humfrz (04-16-2019)
Old 04-16-2019, 03:13 PM   #21
Yep, you're correct, my bad for misquoting him -
Just finished a Walmart run - yes, I survived.
How in the hell did I spend $302.96 at WALMART?
I didn't buy any paper products or cigarettes and the only meat I bought was one pound of hamburger and a pound of sausage, to make meatballs for tonight.
Lunch and a nap will make it all better -
Old 04-17-2019, 12:26 AM   #22
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
i'll check that too
Not a lot, 12 ft-lbs (~16Nm). Be careful not to overdo it.
Old 07-22-2020, 12:50 PM   #23
geezycreezy
geezycreezy's Avatar
Drives: 2013 BRZ Limited
Holy... Wow, I’m so glad I found this thread! Granted I didn’t have to go through as long an ordeal as you, but the past two weeks post-supercharger install I’ve been having an audible tapping noise coming from the passenger side wheel well only at low speeds and every time I’d pull into a parking space. Checked all the suspension bolts and at some point sprayed white lithium grease on the top and bottom spring seats of my coilovers. I even have a Perrin swaybar and bushings still waiting to be shipped out by 86Speed (they’re taking forever, but I’m not in such a bind now at least). Then I realized I had to remove the strut bars for the install and only after reading this post did I remember that the bolts and nuts on the firewall side weren’t properly torqued down because of how tight it got back there with the supercharger/hoses in the way.
So, thanks!
geezycreezy is offline   Reply With Quote
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 12:54 PM
TRD Air Intake Popping Noise ButtonMasher Issues | Warranty | Recalls / TSB 2 03-27-2014 02:18 PM
foot rest popping noise abutterman Issues | Warranty | Recalls / TSB 34 02-20-2014 11:56 PM
Creaking/Clinking Noise from Driver Side Touge86 Issues | Warranty | Recalls / TSB 17 08-17-2013 08:20 PM
BRZ gas pedal popping/squeaking noise chenshuo Issues | Warranty | Recalls / TSB 8 05-10-2013 09:52 AM
