Old 07-17-2012, 02:54 PM   #15
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
Originally Posted by FRSpdDmn View Post
Have you called Perrin for advice?
no man.like i said i didnt imagine this will become such a nightmare for me...
Sall is offline   Reply With Quote
Old 07-17-2012, 02:55 PM   #16
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
Originally Posted by cobrabyte View Post
Heating the bolt? That's the opposite of what he'd need to do.
Just need to pick up a pulley tool that will keep the pulley from rotating while leaning on it with a breaker bar.
I was able to remove mine by putting car in 5th gear and cranking on the hand brake as hard as I could. That bolt is seriously on there!
ima try this when i get home thanks.also does heating the bolt will make it even harder to removed ?
Old 07-17-2012, 02:58 PM   #17
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Well, heat would cause the metal to expand. You'd need to heat the pulley.
I suggest you drive the car for about 10 to 20 minutes and then break the bolt loose. It worked for me and others. Just pick up a breaker bar. I didn't use anything other than that.
cobrabyte is offline   Reply With Quote
The Following User Says Thank You to cobrabyte For This Useful Post:
Sall (07-17-2012)
Old 07-17-2012, 03:00 PM   #18
MKIV
MKIV's Avatar
Drives: 4 tires mounted to 4 wheels
You can use the starter motor along with a breaker bar to loosen the bolt. If you don't know how to do this, take it to a qualified mechanic who's got the proper tool. It's a simple mod so it should not take too much skills to remove it.
MKIV is offline   Reply With Quote
The Following User Says Thank You to MKIV For This Useful Post:
Sall (07-17-2012)
Old 07-17-2012, 03:04 PM   #19
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
yea i heard of this method thanks.
Old 07-17-2012, 03:15 PM   #20
Calum
That Guy
Drives: 2013 asphalt FRS MT
What am I missing here, why not just put the tranny in 6th gear to lock the engine? Or does the OP have an auto.
Old 07-17-2012, 03:24 PM   #21
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
i have a manual. ima try this today afternoon.my only concern is if the heat bolt and going the wrong way from my mechanic maybe made the bolt even harder to loose....hopefully no
The Following User Says Thank You to Sall For This Useful Post:
cobrabyte (07-17-2012)
Old 07-17-2012, 03:55 PM   #22
sparks
sparks's Avatar
Originally Posted by Starscream15 View Post
I ended up using my torque wrench to get it loose. It was the only wrench long enough to get the necessary leverage on the bolt.
I bet it had over 125 lbs of torque on it from the factory.
The HTML manual says 20 flb, then another 90 degrees
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 07-17-2012, 03:55 PM   #23
cobrabyte
cobrabyte's Avatar
Probably not. That is unless, of course, he stripped the bolt with all his shenanigans. You should be fine. Positive thoughts...
Sall (07-17-2012)
Old 07-17-2012, 03:56 PM   #24
vividracing
vividracing's Avatar
Deep breath..... Get Perrin to send you a instruction pdf, Take a look and learn it. Then bring it all back over to the tech. Then learn and work it out together. You will come out ahead in the long run. Take that over to the dealer and your going to hear the word "void"
vividracing is offline   Reply With Quote
The Following 2 Users Say Thank You to vividracing For This Useful Post:
cobrabyte (07-17-2012), Sall (07-17-2012)
Old 07-17-2012, 03:59 PM   #25
cobrabyte
cobrabyte's Avatar
Forgot to mention...
Take a photo of your serpentine belt path with your phone. The diagram included in the instructions is a different motor. Save yourself the hassle of tracking down the belt path.
The Following 2 Users Say Thank You to cobrabyte For This Useful Post:
Sall (07-17-2012), vividracing (07-17-2012)
Old 07-17-2012, 04:06 PM   #26
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
I unplugged my sparkplug wires and used the starter motor plus breaker bar on my stubborn impreza.... Worked great, should have done it as soon as it gave me a hard time. Good luck, it really shouldnt take 30min.
chulooz is offline   Reply With Quote
The Following User Says Thank You to chulooz For This Useful Post:
Sall (07-17-2012)
Old 07-17-2012, 04:17 PM   #27
Calum
That Guy
Don't heat the bolt, please. You're not going to screw up the bolt, but the parts & seals near that aren't made for that kind of heat, and those you could screw up. I don't know if the bolt is left hand or right hand thread, but find out before you start. Over tightening can destroy the bolt and the crank, I've seen both done in the past. To be honest, at this point I'd try to find a replacement bolt as that one may have been stretched to the yeild point, especially considering the torquing method listed by sparks. That sort of torque method, to the best of my knowledge, is either used for torque to yield or Belleville spring washers.
The Following User Says Thank You to Calum For This Useful Post:
Sall (07-17-2012)
Old 07-17-2012, 05:10 PM   #28
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
and
[ame="http://www.youtube.com/watch?v=eS65dyvWvbM"]How To: Remove your Crank Pulley on a Subaru Outback - YouTube[/ame]
might help
Snoopyalien24 is offline   Reply With Quote
The Following User Says Thank You to Snoopyalien24 For This Useful Post:
Sall (08-14-2012)
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
BRZ LED lights installed KI_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 24 07-04-2012 05:34 PM
