Drives: 2017 Halo 86
Quick Q on Injectors & Coils
There's no actual performance gains in upgrading injectors and ignition coils on a stock engine, correct? These are just only for a bump in combustion efficiency mostly beneficial to FI applications is my current understanding. Just looking to confirm.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
| The Following User Says Thank You to Lakitu For This Useful Post: | Boris_Petrov (04-15-2019) |
#2 |
Drives: UK GT86
Not efficiency, it's for when you run out of injector capacity when you fill the cylinders with more air. Not seen anyone upgrade the coils except for those that have had ones fail.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Lakitu (04-15-2019) |
#3 |
Drives: 2005 Toyota Camry
Injector capacity = horsepower output. You upgrade based on target HP output + rest of engine build.
Ignition coils, same as above if you have/foresee ignition issues with your setup. It's a blanket statement but these are things you don't upgrade for the sake of upgrading. |
#4 |
Beautifully said, gentlemen. Thanks!
| Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers | b2autodesigns | Brakes, Suspension, Chassis | 818 | 09-10-2017 08:33 AM |
| FS: NRG Quick Release 3.0, Quick Lock, Steering Wheel | akiranakayama | Interior Parts (Incl. Lighting) | 13 | 08-16-2016 10:40 AM |
| FS: New NRG Quick Tilt & As-Is NRG Quick Release | bear89103 | Interior Parts (Incl. Lighting) | 2 | 10-16-2014 01:11 AM |
| FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel | Pekingduck | Interior Parts (Incl. Lighting) | 7 | 02-12-2014 05:59 PM |
| Quick Release or Quick Lock Steering Wheel and Theft defense too? | 1086 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-24-2014 04:50 PM |
