Old 04-11-2019, 11:36 PM   #1
incutebus
Drives: Boosted
Ecutek showing boost target hitting 19.9?
I have a high boost map set on 10psi, but when I took a look at the logs it shows 19.9 on wot. Is this an overboost? It definitely did not seem anywhere near 20psi of boost.
incutebus is offline   Reply With Quote
Old 04-11-2019, 11:48 PM   #2
Mr_Eyo
Drives: 2017 Toyota 86
Units? 10 psi is almost 20 inHg.
Mr_Eyo is offline   Reply With Quote
The Following User Says Thank You to Mr_Eyo For This Useful Post:
incutebus (04-12-2019)
Old 04-12-2019, 12:37 AM   #3
incutebus
Drives: Boosted
You know that's probably it. Genius!
Old 04-12-2019, 01:17 AM   #4
86TOYO2k17
Drives: 2017 toyota 86
14.7 is ambient, ecutek is reading 5.2psi the max ecutek reads with stock uncalibrated map sensor.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
tomm.brz (04-12-2019)
Old 04-12-2019, 01:22 AM   #5
steve99
Drives: FT86
As above manifoid pressure is logged reliative to atmospheric. So actual boost is loiged boost minus about 14 psi. Log manifold pressure with ignition on and motor off you will see.
DeliciousTuning (04-12-2019)
Part out tails, boost controller, ecutek Stevenduarte210 Exterior Parts (Aero, Lighting, Etc.) 3 07-02-2018 05:30 PM
FS: SBD Turbo kit with oil cooler, boost controller, ecutek cable Sniper2606 Engine, Exhaust, Bolt-Ons 12 08-14-2014 11:52 AM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 05:10 AM
Ecutek boost control with ebcs help. gdrider77 Software Tuning 11 02-02-2014 10:06 PM
Guys running EcuTek boost control ATSAaron Forced Induction 14 09-14-2013 04:08 PM
