Old 04-10-2019, 02:51 AM   #15
BRZBlack
BRZBlack's Avatar
Drives: 2013 Subaru BRZ
Something similar happens to me but only after I start driving right after cold start (not letting the car warm up) and on very cold days. I will be in 1st and the car feels like it bounces. Clutch is fully engaged. Goes away after a few minutes of driving though. I don't pay attention to it anymore really.
BRZBlack is offline   Reply With Quote
Old 04-10-2019, 03:41 AM   #16
Brz-123
This is kangarooing and is a characteristic of our cars, especially till the engine warms up on very cold days. Does not quite happen in summers, right?
Sent from my FIG-LX1 using Tapatalk
Brz-123 is offline   Reply With Quote
Old 04-10-2019, 09:23 AM   #17
jc7993
Drives: Looking to buy
This is common for BRZs? I usually let the car idle during cold startup until the rpm drops from 1.5k to around 1k rpm before I start driving. I usually have to hold the clutch in 1st for more than 3 seconds to avoid “kangarooing”. I might also have a lead foot and am not delicate enough with adding a smidge of gas... usually overstep the pedal and bringing the rpm to 2.5k...
jc7993 is offline   Reply With Quote
Old 04-10-2019, 10:30 AM   #18
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Easy fix. Press the pedal farthest to the right more.
Old 04-10-2019, 11:44 AM   #19
Brz-123
Yes it is. Changing gears is one example but it happens even if you ease the throttle at any gear, when the engine is cold. For the first km or so after starting, then it gets normal. I guess its engine coming upto working temperature.
The Following User Says Thank You to Brz-123 For This Useful Post:
jc7993 (04-21-2019)
RPM's bouncing from 800-1100 on repeat, extremely low fuel trims, logs voidn0ise Issues | Warranty | Recalls / TSB 0 06-16-2017 06:39 PM
Bouncing revs Ondreiko Engine, Exhaust, Transmission 40 08-11-2015 05:10 AM
vid of dealership bouncing frs off rev limiter Big T FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 95 08-01-2012 11:54 PM
