Old 04-09-2019, 07:35 AM   #15
tomm.brz
Drives: brz 2017 hksv2
Yes, got the BT but i really want to keep it simple and manual with windshield lever
Also lazy to remove EVAP system
actually i already eliminated headlights washers cause the hks sc requires so, I would redirect windshield washers to intercooler (and keep a spray bottle in car for extreme necessities, glass are nanocoated and they require very little effort to clean) so basically I would need help on how to disable wipers with an on/off switch, cause I tried to understand which cable to cut, but I don't
Old 04-09-2019, 10:30 AM   #16
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by Kodename47 View Post
CPC control would be the best option. Got the BT EVI? Then you could use that to control the spray manually or have it so that it does it based on temps etc. Did something similar with WMI on a Sprintex setup.
Otherwise I would tap into the headlight washers and find a way to deactivate the windscreen pump and wipers.
Curious to what you did for your WMI setup? I have the AEM WMI flow based on boost (tapped the map plate) with the AEM failsafe, using the flex fuel CPC ECU harness wired to the failsafe to automatically pull a bunch of timing if a failsafe is triggered. also have the sprintex aswell.
Old 04-09-2019, 04:04 PM   #17
Kodename47
Kodename47's Avatar
Drives: UK GT86
It would be the Evap solenoid output rather than the CPC input, my mistake. Using the solenoid to control a relay and adjust the amount of spray depending on a number of factors like speed, RPM, boost and intake temps. Also means you could have it only operational on certain map modes.
.: Stealth 86 :.
Kodename 47 DJ:
Turbo kit using Innovate Air-2-Water Intercooler? iBoost Forced Induction 26 09-26-2014 05:36 PM
Water in vortech intercooler piping and intake box Frs32907 Forced Induction 10 02-10-2014 10:02 PM
Need ideas on how to use this water-repelling spray on car DuMa Scion FR-S / Toyota 86 GT86 General Forum 20 06-26-2013 01:00 AM
Another turbo with but water to air intercooler ahaghshenas Forced Induction 8 09-24-2012 02:22 AM
